SB Gear Drives and Timing #1553528
12/26/13 07:13 PM
12/26/13 07:13 PM
Muncie
Racebuddy Offline OP
Muncie
My Timing concern"
My new E-85 418 W-2 motor will not start. Have had the engine shop install the Milodon gear drive and put my roller from 108 to 104 centerline. I have cam paper info lost in the house but its --
609 lift 272/265 dur. Comp.
I can't identify the exact spec on cam but it appears that the No. 1 intake valve is starting to open up at 45-46 degrees BTDC. Thats with the .028 lash.
I see alot of roller cams opening from 42 to 48.
My motor should run shouldn't it?
My distributor is phased good and the crank trigger is working and putting out strong spark. Hasn't hit a lick, kicks starter out, coughs hard thru carb some.
working the pick-up adjuster full range didn;t seem to help any either
Ideas??
Re: SB Gear Drives and Timing [Re: Racebuddy] #1553529
12/29/13 06:07 PM
12/29/13 06:07 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well see where it gets to .050 lift at the lifter with 0 lash (or .075 at the valve with 1.5 rockers again 0 lash) should be 32 right now sounds like your reading the early ramp.
You numbers would indicate say 300 degree at 0 loft so about it for a 272 @ .050 cam.
My guess would be the dizzy is 180 out they are in phase 2 twice but only on compression once!
Re: SB Gear Drives and Timing [Re: Dodgem] #1553530
12/29/13 09:02 PM
12/29/13 09:02 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Pull a plug. Hold finger over the hole and crank. If it blows your finger off the hole it should start.
You sure the distributer is not 180 out. Sure sounds like it.
Re: SB Gear Drives and Timing [Re: Racebuddy] #1553531
12/29/13 09:12 PM
12/29/13 09:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My Timing concern"
Ideas??
I dont know how cold it is in Muncie but E-85 doesnt
like to fire up when its cold... plus I have to pump
it a few times when its above 50* otherwise it will
fart back through the carb(its lean)... but the valve
opening is about right.. its easier for me to check
it at the top of the lift with zero lash
Re: SB Gear Drives and Timing [Re: MR_P_BODY] #1553532
12/29/13 11:47 PM
12/29/13 11:47 PM
Muncie
Muncie
Thank you for the reply's
Distributor is not 180 out. I have done all the usual things to prepare for the motor to run. It almost started once. It seems like the motor doesn't crank fast enough for it to fire.
Very confusing, thinking about just throwing a chain on it just to see if that makes a difference.
Re: SB Gear Drives and Timing [Re: Racebuddy] #1553533
12/29/13 11:57 PM
12/29/13 11:57 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I think I would find the reason for this first.
Re: SB Gear Drives and Timing [Re: Racebuddy] #1553534
12/30/13 12:08 AM
12/30/13 12:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I sure wouldnt do that... a chain or gear drive does
the same thing... I run the gear drive on most of
my engines and if you set the cam in right it wont
matter what turns the cam... check your spec at the
top of the lobe.. if its to what your spec is then
look elsewhere ... but like I said.. E-85 is a bitxh
to fire when its 50 or below... not real bad at 50
but it sure gets hard to lite at 45
Re: SB Gear Drives and Timing [Re: Racebuddy] #1553535
12/30/13 01:26 AM
12/30/13 01:26 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
It sounds like dizzy 180 off to me also. Make sure you have a good ground from chassis to block. Put a battery charger on boost while cranking to start. You want 10+ minimum volts while cranking. If using manual choke leave about 3/16" gap from blade to body.Too much gap = Lean and that = pop back through carb. Gas needs to be fresh, not sittting in tank for months.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: SB Gear Drives and Timing [Re: Racebuddy] #1553536
12/30/13 01:34 AM
12/30/13 01:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
My Timing concern"
Ideas??
I would go back to square one... set the crank trigger
up for 34* and the dist at #1... if you degreed the
cam in then that part is right.... if need be start
it on gas till you get it to run... at least gas will
fire up.... pull a plug or two and see if they are wet
Re: SB Gear Drives and Timing [Re: MR_P_BODY] #1553537
12/30/13 04:53 PM
12/30/13 04:53 PM
Muncie
Muncie
Very little compression. Should have a ton of it on this 600 hp SB
2 batteries in trunk plus the battery charger full blast on it. volt meter drops to almost 8 when cranking.
Going ahead and pulling front off of it. Super disappointed. Never had a new engine fail to start.
Re: SB Gear Drives and Timing [Re: Racebuddy] #1553538
12/30/13 06:35 PM
12/30/13 06:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Try turning the engine with a torque wrench to see
how much effort there is... I do this on my junk
but I dont have the push rods in or the plugs... I
usually get between 19# on thin rings and 27# on the
1/16 rings... but 27# is the highest I have had on
my street junk... you could have multiple issues why
its not starting... good luck in your quest
Re: SB Gear Drives and Timing [Re: Racebuddy] #1553539
12/30/13 07:09 PM
12/30/13 07:09 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
As mentioned earlier sounds like a poor ground issue, there should not be that great of a voltage drop.
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: SB Gear Drives and Timing [Re: MR_P_BODY] #1553540
12/30/13 07:20 PM
12/30/13 07:20 PM
Muncie
Muncie
OK sorry for the hassle.
Took the front off and removed the plugs again.
it has compression and it is substantial so that was a Lie I told you guys.
compression blasts at about 50- 35 BTDC on the balancer. Can't get exact cause timing cover removed.
Intake valve starts to open around 40 or so.
The marks made on the three gears from the machine shop only line up once and when they do its seems to be out in left field.
Calling my machinest and seeing if he will make a house call to look at it. I just can't get my mind around it.
Thanks for help fellas
Re: SB Gear Drives and Timing [Re: Racebuddy] #1553541
12/30/13 07:31 PM
12/30/13 07:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bring the #1 intake up on total lift and see what
the balancer says(put the cover on to get the reading)
Re: SB Gear Drives and Timing [Re: MR_P_BODY] #1553542
12/30/13 08:15 PM
12/30/13 08:15 PM
Muncie
Muncie
On compression stroke the intake valve is all the way open at 250, give or take a couple.
very perplexed about when my marks align.
thinking i could put a chain on it to ensure my timing is correct, then swapping the gear drive back on.
I think my brain is turning into radioactive jelly
Re: SB Gear Drives and Timing [Re: dartman366] #1553543
12/30/13 11:56 PM
12/30/13 11:56 PM
Muncie
Muncie
Yes I am concerned about the voltage thing. Have battery cable neg grounded to chassis/rollbar post plate, 67 B Body . Going to run battery ground to motor now. have two ground straps front engine to body for additional groundage.
On my timing... it seems to me, the motor has compression at No. 1 at the right timing mark. This is spot on No. one dist. cap post with my cap. Early on I had taken the dist. out and flipped it 180 two different times to see if I could get that to work. No Go.
When my marks align on the three gears, the dist. button
is pointing toward No. 3 and 6.
I'm gonna take pics in morning and maybe a video of how it acts when starting. I don't know what the marks are telling me.
