22" Radiator width #1553524
12/26/13 06:22 PM
12/26/13 06:22 PM
Chicago
curbman68 Offline OP
Chicago
Does anyone know the correct width between the mounting bolt holes for a 22" radiator? Core support on the car measures about 24 1/4" center to center, holes on new radiator are slightly wider and will not bolt in. Trying to figure out which is messed up, car or radiator.
Re: 22" Radiator width [Re: curbman68] #1553525
12/26/13 10:52 PM
12/26/13 10:52 PM
What car
Re: 22" Radiator width [Re: RapidRobert] #1553526
12/26/13 10:56 PM
12/26/13 10:56 PM
Cottage Grove, MN
K
kurtsdodge Offline
kurtsdodge  Offline
K
Cottage Grove, MN
On my 1969 B-Body I measure about 24 and 7/16ths center of bolt to center of bolt. That is on the top.
Re: 22" Radiator width [Re: kurtsdodge] #1553527
12/27/13 12:14 PM
12/27/13 12:14 PM
Chicago
Chicago
Car is 65 B body, did the dimensions change depending on year or body with the same size radiator core?
