Re: Low Dodge
[Re: bigdad]
#1553268
12/26/13 10:03 PM
12/26/13 10:03 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Back up about 50 years and I rode to high school in a truck like that. Just (a lot) taller and rougher, though. The owner traded it in on a new 66 Dodge 1/2 ton long bed with a 318 and 4 speed. He and I used to drive tow trucks back in the day and now he owns that towing outfit.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: Low Dodge
[Re: bigdad]
#1553271
01/28/14 11:03 PM
01/28/14 11:03 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
I'd rather have something I can drive. I don't trust air bags, seen too many fail to feel comfortable with them. Mine was low enough the bottom of the front bumper was scrapped up pretty bad, and the front lower edge of the running boards were beat up pretty bad. Gene
Re: Low Dodge
[Re: Webster]
#1553273
01/31/14 02:02 PM
01/31/14 02:02 PM
Posts: 2,143 Port Saint Lucie, FL
ChallengerGary
Not as low but low
OK - is that yours? If so, how did you get the rear so low? I have a customer with a '60 Town Panel that wants to lower it but if I flip the axles he will have less than 2" of travel and i am afraid it will bottom out on the slightest bump
Re: Low Dodge
[Re: ChallengerGary]
#1553274
01/31/14 03:03 PM
01/31/14 03:03 PM
Posts: 2,833 Ontario Canada
Webster
Ontario Canada
Not as low but low
No it's not mine ,but talked to the owner and it's on air bags a real nice truck...
Re: Low Dodge
#1553275
02/04/14 12:42 AM
02/04/14 12:42 AM
poorboy
Freeport IL USA
Not as low but low
The leaf springs mount to the outside of the frame, If you remount the spring perches higher on the frame, (I think upside down works) it will lower the rear about 1/2 the amount flipping the axle does. Not the lowest, but better then standard. Gene
Re: Low Dodge
[Re: poorboy]
#1553276
02/04/14 11:24 AM
02/04/14 11:24 AM
ChallengerGary
Not as low but low
Thanks - i will take a look at that.
Re: Low Dodge
[Re: bigdad]
#1553279
02/09/14 12:40 PM
02/09/14 12:40 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
Sorry, but I like mine a little better.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Low Dodge
[Re: bigdad]
#1553283
02/23/14 05:28 AM
02/23/14 05:28 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
nice stuff on this topic,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
