96 dodge ram cruise control failure #1553226
12/26/13 03:39 AM
12/26/13 03:39 AM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
Cruise stopped working,cruise on light works but nothing else neither the set or accelerate.Anyone have any ideas what to check?
Re: 96 dodge ram cruise control failure [Re: jst19600] #1553227
12/26/13 10:04 AM
12/26/13 10:04 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
The unit is mounted under the battery. Several reports of battery acid problems with wiring. Check the vacuum connections. I've had a squirrel chew through the harness more than once. Must be pretty tasty?
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 96 dodge ram cruise control failure [Re: jst19600] #1553228
12/27/13 12:41 AM
12/27/13 12:41 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
1. Clockspring in the steering column.
2. All the cruise control wiring in the steering column: Check for broken wires if you have a tilt wheel, especially if you live in a cold climate. Everytime the wheel gets moved up and down those wires get yanked on. They are fine enough that it takes very little to break them.
3. Lube the cruise control cable. If the cable pulls too hard the cruise can be disabled (on newer Rams anyhow).
Mo' Farts
Moderated by "tbagger".
