Proform main body's..... do they work good????
#155310
11/23/08 02:53 PM
11/23/08 02:53 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
I have a holley 3310 on my 390 combo and need to give it a real tune..... I want to keep the vac secondary as I will be using the car on the street alot and don't want to kill my mileage with a double squirter. I bought the proform body for the vac secondary and it is a very nice piece. I also got the secondary block conversion so I can run regular jets in the back for tuning. I also picked up the accel pump cam kit and the quick change vac seconary spring kit with springs and a summit box of jets as well.
So I should be able to get this carb dialed in now and I am wondering what I should use as a baseline jet setting??? My secondaries were opening up way to soon with the light spring so that needs to change as I had very poor throttle response down low. My combo is as follows:
318 block 4" +.030 390 cubes 9.7-1 C/R .044 quench Iron magnum heads ported 2.02/1.625 comp HYD XE-275HL cam 231/237 duration .50 .565 lift Hooker 1 3/4 headers 3" collector 3" exhaust to rear Edelbrock torker 2 intake single plane 3.73 gear 8 3/4 rear A-999 trans 2.74 low gear 2,600rpm stall Car is 83 cordoba 3600lbs?
TIA TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
