A, B, E Front Frame Dimensions? #155296
11/23/08 01:27 PM
11/23/08 01:27 PM
Leesburg, VA
V
VA_Mopars Offline OP
V
Leesburg, VA
I am looking to build a temp front-end dolly so I can work on the front suspension. I found some great pictures in the tech archive, but have some questions...
Does anyone else have a better set-up that are not in the tech archives?
Does anyone know the distance between the front K-Frame bolts on A, B and E body frames?
I want to make sure that what I build will work on each of these body styles..
Thanks in advance,
Joe
A, B, E body Front Frame widths / K-Frame dimensions? [Re: VA_Mopars] #155297
11/23/08 07:15 PM
11/23/08 07:15 PM
Leesburg, VA
V
V
Leesburg, VA
I know someone out there knows the different widths of A - B & E body frame rails...
Anyone?
Thanks,
Joe
Re: A, B, E body Front Frame widths / K-Frame dimensions? [Re: VA_Mopars] #155298
11/23/08 08:25 PM
11/23/08 08:25 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
Well, I don't have exact measurements but I'll tell you what I am doing. I built this set-up for my '68 Charger and I now have it on my '67 GTX. This December I am pulling the engine/K-frame from my '70 Dart and I have found that the A-body is "about" 1 3/4" narrower than the B-body. I will be using a 7/8" spacer on each side with some longer bolts to make it work with the A-body.
Aren't the E and B-body K frames the same?
Stan
Re: A, B, E body Front Frame widths / K-Frame dimensions? [Re: HemiStan] #155299
11/23/08 08:35 PM
11/23/08 08:35 PM
Leesburg, VA
V
V
Leesburg, VA
Thanks, that set up looks great and easy...
Re: A, B, E body Front Frame widths / K-Frame dimensions? [Re: VA_Mopars] #155300
11/26/08 04:45 PM
11/26/08 04:45 PM
Leesburg, VA
V
V
Leesburg, VA
Okay, I measured the distance from outer frame to outer frame on a 69 charger and came up with 36 1/4"... Does that seem correct to everyone?
Thanks,
Joe
Re: A, B, E body Front Frame widths / K-Frame dimensions? [Re: VA_Mopars] #155301
11/26/08 05:01 PM
11/26/08 05:01 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
I just measured my GTX. 36 1/4" it is.
Re: A, B, E body Front Frame widths / K-Frame dimensions? [Re: HemiStan] #155302
11/26/08 05:17 PM
11/26/08 05:17 PM
Leesburg, VA
V
V
Leesburg, VA
Great, cutting, welding and turkey...
Starting to sound like a great Thanksgiving!
Thanks again,
Joe
