Adding a Sunroof #1552919
12/25/13 11:52 AM
12/25/13 11:52 AM
Western Pa
farmboy70 Offline OP
Western Pa
I recently was able to get a factory sunroof and power windows from a parts car.
I am going to add it to my Challenger.
This is a little scary cutting such a large hole in the car.
Here are some pictures of the progress.
Merry Christmas
Re: Adding a Sunroof [Re: farmboy70] #1552920
12/25/13 11:53 AM
12/25/13 11:53 AM
Western Pa
Western Pa
more
Re: Adding a Sunroof [Re: farmboy70] #1552921
12/25/13 11:55 AM
12/25/13 11:55 AM
Western Pa
Western Pa
another
Re: Adding a Sunroof [Re: farmboy70] #1552922
12/25/13 12:01 PM
12/25/13 12:01 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Ah Yeah!!! Looking good so far..
Re: Adding a Sunroof [Re: johnscudashop] #1552923
12/25/13 12:04 PM
12/25/13 12:04 PM
Western Pa
Western Pa
The tricky part is I'm trying to save the gator grain top that is already on it.
So far it looks like it is going to work.
I need to mount the box permently and finish cut the roof panel.
Re: Adding a Sunroof [Re: farmboy70] #1552924
12/25/13 03:02 PM
12/25/13 03:02 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Looking good so far Dave, you are a very brave man!
Re: Adding a Sunroof [Re: 70440+6bbl] #1552925
12/25/13 06:13 PM
12/25/13 06:13 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Indeed!
Re: Adding a Sunroof [Re: Tempest] #1552926
12/25/13 06:32 PM
12/25/13 06:32 PM
Western Pa
Western Pa
Not brave, crazy
Re: Adding a Sunroof [Re: farmboy70] #1552927
12/26/13 02:31 PM
12/26/13 02:31 PM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
A heat gun works wonders on the vinyl top if you need to work around it. I peeled back quite a few originals to fix the bad factory seam under the sail panel areas. It goes back on quite nicely. Never peeled back a gator top but pretty sure it will work the same.
Here are a couple pics.
Re: Adding a Sunroof [Re: mymcodebee] #1552928
12/26/13 02:32 PM
12/26/13 02:32 PM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
Repaired and glued back down.
Re: Adding a Sunroof [Re: mymcodebee] #1552929
12/26/13 03:27 PM
12/26/13 03:27 PM
Western Pa
Western Pa
Very nice work.
Re: Adding a Sunroof [Re: farmboy70] #1552930
12/30/13 10:37 PM
12/30/13 10:37 PM
Western Pa
Western Pa
All the drains are run and the box is installed.
Waiting until it is cured and then some spot welds.
Re: Adding a Sunroof [Re: farmboy70] #1552931
01/03/14 07:34 PM
01/03/14 07:34 PM
minnarusta
TX9H6E4CUDA Offline
TX9H6E4CUDA  Offline
minnarusta
Update please!!!!! With more pictures!!!
What did you do to make the roof edge for the sunroof? Did you cut and splice a piece in or did you form the edge using existing metal?
I'm planning out my Superbee to get a sunroof.
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Adding a Sunroof [Re: TX9H6E4CUDA] #1552932
01/06/14 03:47 PM
01/06/14 03:47 PM
Western Pa
Western Pa
Been down with the flu and should get back to it soon.
The flange is the box once installed.
There were many spot welds around the outside of the opening.
Looks as though the company installing these mounted the box ,cut the hole and then spot welded the edge and finish ground it.
On the rear corners they left s little extra and folded under there.
I checked the new top material against what was on the car and the color of my top has faded some so I am going to remove it and install the complete top now.
New slider panel material should arrive from Legendary next week.
Re: Adding a Sunroof [Re: farmboy70] #1552933
01/17/14 11:54 PM
01/17/14 11:54 PM
Western Pa
Western Pa
Got the top material on !
Here are some pictures.
Re: Adding a Sunroof [Re: farmboy70] #1552934
01/17/14 11:55 PM
01/17/14 11:55 PM
Western Pa
Western Pa
Re: Adding a Sunroof [Re: farmboy70] #1552935
01/19/14 01:39 AM
01/19/14 01:39 AM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
THAT TOOK BALZ....
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Adding a Sunroof [Re: 72N96RR] #1552936
01/26/14 02:30 PM
01/26/14 02:30 PM
Western Pa
Western Pa
Started adding the headliner.
Here we are using the bows to pull it up around the top opening.
We are reusing the headliner that was in the car before the sunroof.
The trick was to get the holes from where the mirror , visors , ect to line up.
It came out good.
Re: Adding a Sunroof [Re: farmboy70] #1552937
01/26/14 02:33 PM
01/26/14 02:33 PM
Western Pa
Western Pa
Re: Adding a Sunroof [Re: farmboy70] #1552938
01/26/14 02:47 PM
01/26/14 02:47 PM
Mrytle Beach SC
Mrytle Beach SC
Following this on Cuda-Challenger.com . I like how you have been able to keep the gator grain top. Its alot of work but worth it... Looks great..
