Testing MSD RPM-Activated Switch #1552661
12/24/13 07:36 PM
12/24/13 07:36 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
Just got my car running and have a msd 8950 RPM-Activated Switch to shift and put a 3000 chip in it and it doesn't shift. If I put 12 volts to shifter it will shift. Is there anyway to test the msd RPM-Activated Switch? Or time for a new one?
Re: Testing MSD RPM-Activated Switch [Re: Plymouth340] #1552662
12/24/13 08:26 PM
12/24/13 08:26 PM
iowa
wesw Offline
wesw  Offline
iowa
if you have the MSD 8998 tester you can hook it up and check your complete system out
598 ci predator
Re: Testing MSD RPM-Activated Switch [Re: Plymouth340] #1552663
12/24/13 09:15 PM
12/24/13 09:15 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Doesn't the rpm switch complete the ground side two grds don't make it hot.
Re: Testing MSD RPM-Activated Switch [Re: JD Dart] #1552664
12/24/13 10:48 PM
12/24/13 10:48 PM
CEDAR RAPIDS
CEDAR RAPIDS
gray wire witch I don't use does. I use yellow wire witch makes it hot when activated.
Re: Testing MSD RPM-Activated Switch [Re: Plymouth340] #1552665
12/25/13 02:31 AM
12/25/13 02:31 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Both wires make a ground. not hot
Re: Testing MSD RPM-Activated Switch [Re: Plymouth340] #1552666
12/25/13 03:30 AM
12/25/13 03:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You are using a relay to trigger the shifter.. right
the chip will complete the ground to trigger the relay
Re: Testing MSD RPM-Activated Switch [Re: SB412DUSTER] #1552667
12/25/13 12:30 PM
12/25/13 12:30 PM
CEDAR RAPIDS
CEDAR RAPIDS
Thanks I will recheck the wiring. maybe I have wrong solenoid for shifter. just put in a different style one and always used yellow wire from rpm switch to solenoid.thanks
