Stall converter installation #155233
11/23/08 11:10 AM
11/23/08 11:10 AM
Illinois
Rick57 Offline OP
Rick57  Offline OP
Illinois
After sliding the stall converter on the 902 tansmission spline should it be able to turn freely?
Re: Stall converter installation [Re: Rick57] #155234
11/23/08 11:37 AM
11/23/08 11:37 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Should turn pretty freely. You will likely have to support the center of the converter as you spin it (like the engine would).
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Stall converter installation [Re: GoodysGotaCuda] #155235
11/23/08 01:51 PM
11/23/08 01:51 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Make sure that it drops in far enough. There should be 2 distinct detents or drops before it is seated deep enough. the face of the converter will be 3/4 of an inch back from the leading edge of the belhousing. If it isn't in deep enough it will bind on installation and not be seated into the front pump. DO NOT continue installing if this is the case. The converter should have to be pulled forward to mate up to the flex plate. There is only one position that it will bolt to the plate.
902 transmission??????
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
