Page 2 of 11 1 2 3 4 10 11
Re: My Gen III Hemi A-body Borgeson marriage [Re: 68cuda440] #1552287
01/29/14 12:13 AM
01/29/14 12:13 AM
Nebraska
72Swinger Offline OP
Nebraska
You realize you are going against Mopar convention, the oil filter has to hang over something so that it can not be removed without making a mess that is impossible to clean up.
What do you mean? Cant you see, I can still soak the swaybar pretty easy if its cold and I shake a little....
Mopar to the bone!!!
Re: My Gen III Hemi A-body Borgeson marriage [Re: amxautox] #1552288
01/29/14 12:14 AM
01/29/14 12:14 AM
Nebraska
Nebraska
Heck mine is even easier to get to than that one.
You damn AMC guys are spoiled rotten with your dizzy and oil filters all up front and crap....
Re: My Gen III Hemi A-body Borgeson marriage [Re: 72Swinger] #1552289
01/29/14 12:16 AM
01/29/14 12:16 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
But I located my filter location where I wanted it when I installed the oil cooler and all that.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: My Gen III Hemi A-body Borgeson marriage [Re: amxautox] #1552290
01/29/14 07:20 AM
01/29/14 07:20 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
That looks expensive!:)
Re: My Gen III Hemi A-body Borgeson marriage [Re: BigBlockMopar] #1552291
01/29/14 11:05 AM
01/29/14 11:05 AM
Wildwood, FL
1fastabody Offline
1fastabody  Offline
Wildwood, FL
Looks Good! I can't wait to start my Gen III installation.
Re: My Gen III Hemi A-body Borgeson marriage [Re: 1fastabody] #1552292
01/29/14 11:36 AM
01/29/14 11:36 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I'll be ready to buy headers in the next two weeks. I'm not happy about it.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: My Gen III Hemi A-body Borgeson marriage [Re: BigBlockMopar] #1552293
01/29/14 02:09 PM
01/29/14 02:09 PM
Nebraska
Nebraska
Kind of a "better to have a gun and not need it, then to need a gun and not have it" way of thinking with the oil cooler lol.
The new 6.4's all have a cooler plumbed with water.
Re: My Gen III Hemi A-body Borgeson marriage [Re: 72Swinger] #1552294
01/29/14 08:13 PM
01/29/14 08:13 PM
Oh Canada
E
EV2CUDA Offline
EV2CUDA  Offline
E
Oh Canada
Would a borgeson steering box work so you do not have to dent the headers?
If you are retaining the PS, are you going to reduce the output pressure of the mopar hemi pump, by a modified pump or??
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: My Gen III Hemi A-body Borgeson marriage [Re: EV2CUDA] #1552295
01/29/14 08:15 PM
01/29/14 08:15 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
The Borgeson box and TTI headers made for that box dont fit. I saw what Wade, (uhcoog1) had to do and it was depressing.
Re: My Gen III Hemi A-body Borgeson marriage [Re: EV2CUDA] #1552296
01/29/14 08:53 PM
01/29/14 08:53 PM
The Netherlands
The Netherlands
That IS a Borgeson box inthe first pic.
A factory power steering box and a 3rd gen Hemi wouldn't fit at all.
Re: My Gen III Hemi A-body Borgeson marriage [Re: BigBlockMopar] #1552297
01/29/14 09:12 PM
01/29/14 09:12 PM
Oh Canada
E
EV2CUDA Offline
EV2CUDA  Offline
E
Oh Canada
I see now. Will it take the pressure output of the hemi pump? Is there a trick to reduce its output?
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
Re: My Gen III Hemi A-body Borgeson marriage [Re: EV2CUDA] #1552298
01/29/14 09:45 PM
01/29/14 09:45 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
takes it fine
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: My Gen III Hemi A-body Borgeson marriage [Re: EV2CUDA] #1552299
01/29/14 09:54 PM
01/29/14 09:54 PM
Nebraska
Nebraska
my pump is a gm style Saginaw TC pump with a 4.7 Dakota/durango pully pressed on. Bracket made from 1/2" aluminum.
Re: My Gen III Hemi A-body Borgeson marriage [Re: 72Swinger] #1552300
01/30/14 12:33 AM
01/30/14 12:33 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
And here is reality, see attachment above.
But the first line of this thread reads, "Finally got things going in the right direction by making my own mounts and denting $800 headers..."
Look, I like this build, (a lot) but you positioned the engine. I'm guessing that the TTI's were designed to work with Schumacher mounts. just sayin... and wondering!
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552301
01/30/14 01:01 AM
01/30/14 01:01 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Just throwing this question out there?
Is there a definite advantage of a lets say 500 hp Gen III EFI Hemi vs. an old school 500 hp EFI small block?
Don't get me wrong, I was planning to get the Mopar All Aluminum Gen III crate engine and drop that in my car
but when I found out about the Ritter Aluminum small block I figured it would be an easier and less expensive route to go to.
My reasoning is that I already have the Edelbrock heads, headers, transmission placement, blah blah blah, etc..
Besides buying a forged crank, rods and pistons, I basically just have to swap out my current cast iron block with an aluminum one and add a FAST EFI kit that I already have.
I figure that it would still be less than the $14k for the 515hp P5156159 crate engine
http://www.jegs.com/p/Mopar-Performance/Mopar-Gen-III-426-Hemi-Crate-Engine/1710917/10002/-1
Am I missing something here? I know basically nothing about Gen III engines
thanks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: My Gen III Hemi A-body build. [Re: RylisPro] #1552302
01/30/14 01:48 AM
01/30/14 01:48 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Killer small blocks are great, but when you open the hood and there's a Hemi there... well, you know the reaction!
Re: My Gen III Hemi A-body build. [Re: RylisPro] #1552303
01/30/14 02:06 AM
01/30/14 02:06 AM
Nebraska
Nebraska
thanks
There is no huge advantage at 500hp other than maybe fuel mileage. I wanted in the 600+ range and I think there on up it starts to shine price wise and still using a hydraulic roller with 0 maintenance.
Re: My Gen III Hemi A-body Borgeson marriage [Re: Bull1tt] #1552304
01/30/14 02:18 AM
01/30/14 02:18 AM
Nebraska
Nebraska
I dont know what these were designed to work with but me and a few other guys were told they work on Gen III powered A-bodies with a Borgeson steering box. TTI told me to just move engine forward for clearance, AFTER I told them I was making my own mounts. I used to run a BB and my trans mount was already set to stock fore and aft wise. I would've needed to move the engine forward 1/2" to clear the #1 primary. That aint happening because it would require notching K member, steering linkage problems and shifter hole problems. So I decided to egg out the steering box holes and move it outboard about 1/8" and still put in the dent in the tube shown above. Doing this also helped steering shaft clearance at the same time. All TTI has to do is change the #1 tube placement about 3/8" but for some reason they seem very reluctant to. Here is the pic that has mislead me and a few others
Re: My Gen III Hemi A-body build. [Re: RylisPro] #1552305
01/30/14 11:58 AM
01/30/14 11:58 AM
USA
Consulier Offline
Consulier  Offline
USA
thanks
I'm running the 6.4 because it's cheap. 500+ hp for $6,000 with OEM reliability. Can't beat that and you can't get that with a LA motor. If you want more power, it will take it no problem. Drop in some forged slugs (Mahle direct drop in) and slap a blower on the thing and it's making 650 all day.
The harnesses are getting easier. Trans stuff bolts right up. Flywheel is cheap. For some reason the headers just suck.
My 2" did end up fitting with custom mounts and the engine being raised 1/2". Not what I wanted, but that's what I got with off the shelf headers. Using a manual box with an electric steering column, so extra room with the box.
There is some minor massaging required, but nothing major.
Re: My Gen III Hemi A-body build. [Re: Consulier] #1552306
01/30/14 01:32 PM
01/30/14 01:32 PM
Nebraska
Nebraska
Get some Wesley! You keeping the SRV intake?
