Anyone have a Gearvendors OD in their car?? #1552008
12/23/13 05:59 PM
12/23/13 05:59 PM
Lakeland FL
floridian Offline OP
Lakeland FL
My vert is used for just cruising around on a nice day. Has 2.94 rear gears( original 440/727 in it). Have always thought it would be fun to up the rear gears to 3.55 or 3.23, but would like a good hwy cruise RPM without working the motor..
Tell me about your gearvendors O/D?? install, dependability, servicing, any problems?? Thanks
Re: Anyone have a Gearvendors OD in their car?? [Re: floridian] #1552009
12/23/13 07:25 PM
12/23/13 07:25 PM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
I've had a GV in my e-body for 4 years now. It was a easy install with slight dimpling of the floor hump in two places, minor electrical wiring, and having the driveshaft shortened. You will have to remove the tail shaft from your current trans and install the supplied adapter. FWIW the OD is .80 to 1 so not as much OD as some other options out there. I use my car like you describe and have about 3.5K miles on it so far with NO issues.
Re: Anyone have a Gearvendors OD in their car?? [Re: floridian] #1552010
12/23/13 09:35 PM
12/23/13 09:35 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
As already mentioned, those are modifications you will have to perform. I did mine in a weekend plus a Monday for the driveshaft return. Ran the foot switch next to the hi-beam, the toggle into the center console. I have a 440/727 with 3.55s and I can drive 80mph @2200rpm. Had it in there since 2007 and have about 7000 miles on it. She is a weekend car. The only thing I goofed on was the GVO sat up against my H-Pipe for 2000 of those miles and the gasket burned out. They sell em for 6 bucks each and I replaced it already. The downfall you will realize is that you have to to run Mopar Manual Synthetic 75w85 at $15 a quart. I did some digging and found that MT-85 will work just as good from Redline and I bought a few bottles from eBay.
I still can't get the whole synchronization down of shift, OD, shift, OD, to split the gears but the 4th gear overdrive works fine for me
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Anyone have a Gearvendors OD in their car?? [Re: Pyper70] #1552011
12/23/13 10:15 PM
12/23/13 10:15 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
I've had a GV in my challenger since 2005. As said by an earlier poster, pretty simple install.
I'm running 3.91's. Cruise down the SoCal freeways at 70-75 at 2500-2600 rpm.
Absolutely love it.
G-bob's Gearvendors install
Re: Anyone have a Gearvendors OD in their car?? [Re: G_bob] #1552012
12/24/13 01:14 AM
12/24/13 01:14 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I've got one also...Works great one of the best investments for driveability...4:10 dana, 727 and a high stall converter..Ends up with a 3;21 ratio in OD..
Re: Anyone have a Gearvendors OD in their car?? [Re: screamindriver] #1552013
12/24/13 01:44 AM
12/24/13 01:44 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Me too... Have one in my '69 Charger Daytona, 440-727-4.10 Dana car...
Can't find my former thread on here on my install, but here's the thread on the Charger Board I did..
Really the only modification I did was round off the corners of the casting near the floor pan. I did have to "round-out" the floor pan a wee bit using a impact socket to get the "dimple" rather smooth and hardly noticeable.
Gear Vendor thread on my Daytona
Re: Anyone have a Gearvendors OD in their car?? [Re: hemi68charger] #1552014
12/24/13 02:30 PM
12/24/13 02:30 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
They have a fantastic rep, castings are made in England and all machining is done in their U.S. plant. If you plan to keep your Mopar for the long haul, then it is a good investment.
Re: Anyone have a Gearvendors OD in their car?? [Re: 1972CudaV21] #1552015
12/25/13 09:52 AM
12/25/13 09:52 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
there is a very interesting SAE paper where a group in England decided to find out what RPM led to best fuel economy in real world driving
to find out they installed three Gearvendors style OD units in series in place of the driveshaft of an English Ford Escort and drove it at different speeds on different road conditions and loads
Re: Anyone have a Gearvendors OD in their car?? [Re: floridian] #1552016
12/25/13 12:19 PM
12/25/13 12:19 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
DabeastII has one on his small cam 512 69 superbee and it is an awesome set up was easy to install on the tranny (I helped)
Re: Anyone have a Gearvendors OD in their car?? [Re: Dodgem] #1552017
12/25/13 01:50 PM
12/25/13 01:50 PM
BDW Online content
BDW  Online Content
How heavy is the final section. Looks like a long lever arm with no support?
Re: Anyone have a Gearvendors OD in their car?? [Re: BDW] #1552018
12/25/13 02:54 PM
12/25/13 02:54 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
The OD unit itself might weigh 15-20 lbs. The new tailshaft housing/ adapter has about 4 ribs cast into it, and is plenty strong enough to handle that weight. I have had 3 GV overdrives in 3 different vehicles, and they are VERY heavy duty units.
Re: Anyone have a Gearvendors OD in their car?? [Re: JDMopar] #1552019
12/25/13 04:42 PM
12/25/13 04:42 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I haven't owned one but I've driven several cars with them on some long haul rides, If I were building an OD automatic car I wouldn't go any other way than the Gear Vendor unit, they take MAJOR abuse and are a dream to cruise at highway speeds even with a fairly deep rear gear.
For an OD manual trans and a 100% bolt in setup, there's no other choice than the new Passon 5 speed (see pic), they are a BEAUTIFUL piece of workmanship!
Re: Anyone have a Gearvendors OD in their car?? [Re: ScottSmith_Harms] #1552020
12/25/13 04:45 PM
12/25/13 04:45 PM
Harrisburg, Pa.
Harrisburg, Pa.
That's a nice looking unit...Scott are you using that in one of your cars ??? I hope to try one of those out in the near future...
Re: Anyone have a Gearvendors OD in their car?? [Re: screamindriver] #1552021
12/25/13 04:48 PM
12/25/13 04:48 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It's going in my yellow 340 Duster (behind it on the rotisserie). I have limited time to work on it due to my carb business sucking away most of my time so I pick at it when I can. My target completion date is "Summer" of 2014. Most of the major sub assemblies are done now but still a long way to go getting it all put together. We'll see how it goes.
Re: Anyone have a Gearvendors OD in their car?? [Re: floridian] #1552022
12/25/13 04:54 PM
12/25/13 04:54 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
I did the 4L60E overdrive swap in my 69 roadrunner and even though its more expensive then the gear vendors I like it a lot!
Re: Anyone have a Gearvendors OD in their car?? [Re: MidPenMopar] #1552023
12/25/13 09:36 PM
12/25/13 09:36 PM
BDW Online content
BDW  Online Content
If your upgrading the transmission, is the GV still a better option than a 518.
Is the attraction the ease of installation, it's about $3k for the GV right?
Re: Anyone have a Gearvendors OD in their car?? [Re: BDW] #1552024
12/26/13 12:33 AM
12/26/13 12:33 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I was able to put a freshened up 518 behind my 360 for roughly $1500; which included the cost of the trans, having it gone through, and a new Turbo Action torque converter. The 518 I found was a low mileage unit from a wreck. It was labor intensive though as I had to modify the cross member and fabricate a mount. If my car had a big block though I don't think I would have done it as an Ultra Bell would be required.
Re: Anyone have a Gearvendors OD in their car?? [Re: MarkZ] #1552025
12/26/13 09:59 PM
12/26/13 09:59 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Have one in my 67 Coronet 493 with 3.55 gears. Makes cruising down the highway nice as it puts me in the 2.80 something gear range.
Re: Anyone have a Gearvendors OD in their car?? [Re: rapom] #1552026
12/29/13 03:32 AM
12/29/13 03:32 AM
White Creek, NY
408cuda Offline
408cuda  Offline
White Creek, NY
Have one in this car http://youtu.be/Pc-4z5WrNwc 74 cuda 408 stroker and love it. Easy to install, slight dimpling in floor and minor wiring. Evidence above of abuse. Even shifted into 2nd over at the strip WOT,, no gain on my combo but good testament to the shift quality and durability. Wanted to go 518 but they were pretty hard to find at the time for any kind of fair $ and the GV 727 combo is proven tough.
I hear a lot of concerns on driveline angles but I had no problem getting mine good and its one of the smoothest 11 sec cars I imagine you'll see. Well as far as old muscle goes anyhow
Re: Anyone have a Gearvendors OD in their car?? [Re: 408cuda] #1552027
12/30/13 05:44 PM
12/30/13 05:44 PM
Castlegar, BC, Canada
That AMC Guy Offline
One of my longterm projects is installing the Laycock-deNormanville OD in my Gremlin. (Later Gearvendors units are virtually identical to the LdN unit - I can even get parts for it from GV!)
Lucky for me, the LdN unit was a factory option in '75 and '76, even though my Gremlin is a '70 it's still a bolt-in process!
I'm curious to see how it'll perform as it's a three-speed with the OD, and only a 3.08 gear. The steepest gear one could order with the unit is only 3.08.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
