Which T-56 Magnum?
#1551631
12/22/13 06:58 PM
12/22/13 06:58 PM
Posts: 1,328 St. Louis, MO
mopardamo
St. Louis, MO
Hello, Since I have a block with the Mopar and chevy bell housing patterns which T56 magnum should I choose? I know I have to modify the trans tunnel. Wanted some opinions on getting all the parts to make it work with the least amount of problems. Also was wondering who's clutch setup is the slickest one? Thanks Moparts Damon
Re: Which T-56 Magnum?
[Re: mopardamo]
#1551632
12/22/13 08:57 PM
12/22/13 08:57 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
How much power? Street bruiser or launching from 5k repeatedly on slicks? Need more info before anyone can help you make a decision?
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
