Which T-56 Magnum? #1551631
12/22/13 06:58 PM
12/22/13 06:58 PM
St. Louis, MO
mopardamo Offline OP
St. Louis, MO
Hello,
Since I have a block with the Mopar and chevy bell housing patterns which T56 magnum should I choose? I know I have to modify the trans tunnel. Wanted some opinions on getting all the parts to make it work with the least amount of problems. Also was wondering who's clutch setup is the slickest one?
Thanks Moparts
Damon
Re: Which T-56 Magnum? [Re: mopardamo] #1551632
12/22/13 08:57 PM
12/22/13 08:57 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
How much power? Street bruiser or launching from 5k repeatedly on slicks? Need more info before anyone can help you make a decision?
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Which T-56 Magnum? [Re: topfueldart] #1551633
12/23/13 01:10 AM
12/23/13 01:10 AM
St. Louis, MO
St. Louis, MO
Hello,
About 680 hp and weekend racer. Looking to do some drag and twisty track racing. Trying for an all around driving machine. I'd like it to do most anything a Viper can.
Damon
Re: Which T-56 Magnum? [Re: mopardamo] #1551634
12/23/13 02:03 AM
12/23/13 02:03 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I have a buddy getting rid of a modified one that was in an F body. It drove great even with a 4.10 and 27" tire it was great on the interstate if you would be interested.
Re: Which T-56 Magnum? [Re: SpareParts] #1551635
12/24/13 02:17 PM
12/24/13 02:17 PM
St. Louis, MO
St. Louis, MO
Hello SpareParts,
Few questions.
Is it the magnum version?
What year is it and the miles?
What kind of mods?
What was the setup it came from? Meaning things like hp, power adder, slicks etc
Damon
