Front + Rear Dana 60 3.55 to 4.10 gear swap? #1551366
12/22/13 03:01 AM
12/22/13 03:01 AM
VA
AtomicDog Offline OP
VA
I'm seriously considering swapping to 4.10 ring and pinions in my '96 Dodge Ram 2500 4x4 Dana 60 front and rear axles, since I've installed 285/75/16 tires. Does the front axle require reverse rotation gears? Just curious if the front and rear Dana 60s use the same gear set part numbers?
Re: Front + Rear Dana 60 3.55 to 4.10 gear swap? [Re: AtomicDog] #1551367
12/22/13 03:25 AM
12/22/13 03:25 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
reverse rotation gears are used in Hi Pinion diffs. You may need what is called thick gears or new carriers for the 4.10 gears.
I am truckless..
Re: Front + Rear Dana 60 3.55 to 4.10 gear swap? [Re: 340SHORTY] #1551368
12/22/13 04:17 AM
12/22/13 04:17 AM
VA
VA
I do believe the carriers I have will handle 4.10 gears (4.10 and lower numerically) without the need to swap them. Just not sure about the gears needed front and rear - has anyone done this swap on the late model Dana 60's front and rear?
Re: Front + Rear Dana 60 3.55 to 4.10 gear swap? [Re: AtomicDog] #1551369
12/22/13 09:20 AM
12/22/13 09:20 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Contact Dr.Diff he will know what you need.Rocky
Chrysler Firepower
Re: Front + Rear Dana 60 3.55 to 4.10 gear swap? [Re: therocks] #1551370
12/22/13 12:54 PM
12/22/13 12:54 PM
VA
VA
Great idea! I'll give Cass a call.
Re: Front + Rear Dana 60 3.55 to 4.10 gear swap? [Re: AtomicDog] #1551371
12/31/13 05:05 AM
12/31/13 05:05 AM
vashon island washington
hunterstroble Offline
Yes your original carrier will work, did it on my 97 2500 v-10 4x4. What a difference! I had 285's too. Oh, I needed to use a case spreader to get the carrier out of the front diff too. One of the only times I've needed to use one of those, lol.
1969 Dodge dart 500 stroker 1973 Dodge Challenger 440
Re: Front + Rear Dana 60 3.55 to 4.10 gear swap? [Re: hunterstroble] #1551372
01/02/14 12:31 AM
01/02/14 12:31 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I had 4.10 gears in my 01 when I bought it.... HATED those things! to many r's going down the highway. Swapped for 3.55's and was mucho happier. I do still run the 265 series tires as I want towing stability.... and my 01 has the power to work with the 3.5 gear
