'92 floor pan ideas #1551315
12/21/13 11:23 PM
12/21/13 11:23 PM
Kentucky
dfsmopars Offline OP
Kentucky
I bought a '92 D150, 2WD, 5.2 last month with the intention of putting some money in it and flipping it. It is a low mileage, above average truck that is worth a little investment and a chance to be in service as someone's work truck.
The driver's side floor pan in the sunken area is shot. The passenger side is fine. What is the best way to get the floor solid again without spending much money? Can a flat sheet of metal be formed and welded in or does a formed pan have to be purchased. I have a mig welder and all the tools needed to do it. This will be my first attempt at a floor pan. All previous restorations had good pans to start with. I do plan on sealing it real good and hopefully putting a rubber mat in instead of carpet.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: '92 floor pan ideas [Re: dfsmopars] #1551316
12/22/13 12:01 AM
12/22/13 12:01 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
1 question.
If your going to take the time to fix it why not fix it right the first time.. If I was looking for a truck and saw a poor repair Id be worried about what else was jerry rigged.
I am truckless..
Re: '92 floor pan ideas [Re: dfsmopars] #1551317
12/22/13 12:03 AM
12/22/13 12:03 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I had a '74 D100 with a bad drivers floor. When I pulled up the floor mat to work on it I found the floor had been patched with a Pennsylvania license plate
A friend had a mig welder and we welded a piece of sheet steel in place and formed it with a torch and hammer. When I traded it to my son it was still there. No idea where it is now, but I would like to have back the E58 Police 360 that I built for it.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: '92 floor pan ideas [Re: Polarapete] #1551318
12/22/13 12:08 AM
12/22/13 12:08 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
my 92 had a soft pan on the ds. bought a new pan for under $100 and welded it in. good as new.
Re: '92 floor pan ideas [Re: chrisf] #1551319
12/22/13 12:30 AM
12/22/13 12:30 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My old Ram Charger had a real bad floor.I cut a solid floor from an Imperial I was scraping.Fit pretty good and lasted the 5 years I had it.The guy that bought it had it at least 7 years with no problems.Rocky
Chrysler Firepower
Re: '92 floor pan ideas [Re: 340SHORTY] #1551320
12/22/13 12:30 AM
12/22/13 12:30 AM
Kentucky
Kentucky
1 question.
No intention of a "jerry rigged" job. Just not sure what is enough. This is not a '69 RR restoration. This is a job to get this truck back on the road and give someone a good service vehicle for the next 5 to 10 years. I doubt the next buyer will be looking for a collector. The Mopars I sell are all done right, this just happens to be my first non-muscle car.
Re: '92 floor pan ideas [Re: dfsmopars] #1551321
12/22/13 01:25 PM
12/22/13 01:25 PM
Truckville, the capital of NY
85_Ram_4speed Offline
I would just buy a drivers side floor pan for it. For the amount of time your going to spend beating, bending, cutting a piece of steel in there, might as well just put the right thing in it and be done ans save time. And it will fit and be right without alot of money spent IMO.
Outcast Dodge guy.
Re: '92 floor pan ideas [Re: 85_Ram_4speed] #1551322
12/22/13 02:25 PM
12/22/13 02:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: '92 floor pan ideas [Re: 85_Ram_4speed] #1551323
12/22/13 07:17 PM
12/22/13 07:17 PM
Kentucky
Kentucky
Yep I agree. Looks like mill-truck-body and rockauto are good sources. It does look like I'll have to make my own sill plates. Floor pan, sealer, new sound deadening and padding, sill plates, cleaned carpet and one piece floor mat <$150.
Re: '92 floor pan ideas [Re: dfsmopars] #1551324
12/22/13 11:17 PM
12/22/13 11:17 PM
scratchnfotraction Offline
cheap shadetree repair here...I used some 20 gauge sheet metal and welded in my own patch.
patched up the driprail/pinchweld/roof edge then sprayed the cab inside and out with 6 gallons of bedliner...that should keep it rust free a long time.
then swaped it to my 85 truck along with the nv4500 5 speed.
Re: '92 floor pan ideas [Re: scratchnfotraction] #1551325
12/22/13 11:17 PM
12/22/13 11:17 PM
2
Re: '92 floor pan ideas [Re: scratchnfotraction] #1551326
12/22/13 11:18 PM
12/22/13 11:18 PM
3
Re: '92 floor pan ideas [Re: scratchnfotraction] #1551327
12/22/13 11:19 PM
12/22/13 11:19 PM
Re: '92 floor pan ideas [Re: scratchnfotraction] #1551328
12/22/13 11:20 PM
12/22/13 11:20 PM
Re: '92 floor pan ideas [Re: scratchnfotraction] #1551329
12/22/13 11:21 PM
12/22/13 11:21 PM
Re: '92 floor pan ideas [Re: scratchnfotraction] #1551330
12/22/13 11:22 PM
12/22/13 11:22 PM
Re: '92 floor pan ideas [Re: scratchnfotraction] #1551331
12/22/13 11:26 PM
12/22/13 11:26 PM
Re: '92 floor pan ideas [Re: scratchnfotraction] #1551332
12/22/13 11:28 PM
12/22/13 11:28 PM
Re: '92 floor pan ideas [Re: scratchnfotraction] #1551333
12/22/13 11:29 PM
12/22/13 11:29 PM
Re: '92 floor pan ideas [Re: scratchnfotraction] #1551334
12/22/13 11:31 PM
12/22/13 11:31 PM
