SB oil pressure, lifters?
#155109
11/22/08 08:12 PM
11/22/08 08:12 PM
Posts: 803 Oklahoma
Mopar72Man
Oklahoma
Looking to see if ticking lifters can be a cause of lower than normal oil pressure? I have about 15,000 (fairly rough) miles on my engine and the hot oil pressures are what is bothering me. Cold start, I can get up to 70-75psi. Hot, I can get up to 45psi. At idle I run cold about 30-35, hot 15psi...This is with 15w-50 full synthetic (same pressures with 15w-40 I used to run). I do have a little ticking that I believe is lifter related, is there a way that it could be causing the lower pressure?? Thanks
72 Challenger - will be sublime, little 340 904, 8 3/4" - Under Construction
Re: SB oil pressure, lifters?
[Re: mopars4ever]
#155111
11/22/08 09:11 PM
11/22/08 09:11 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Or exhaust leak. Also alot of play on the rocker arms & shafts and there is sometimes some rocker ticking.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#155112
11/22/08 09:47 PM
11/22/08 09:47 PM
RapidRobert
if they only tick when it's down to 15 psi at hot idle my(1st) suggestion would be a thicker oil. It'd be easier/cheaper to do than to R&R the lifters
[Re: RapidRobert]
#155113
11/23/08 10:43 AM
11/23/08 10:43 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
ticking lifters is a symptom, not a cause of your pressure issue.
Now loose lifter to bore clearance might be the cause, but that's not what's ticking.
Could be any number of things causing the low oil pressure you are seeing, but to be honest it's not really that low.
