cometic gaskets #1551082
12/21/13 12:56 PM
12/21/13 12:56 PM
Q
Quicktree Offline OP
Q
did you guys spray the copper coat on them between layers when they were new? I did on used ones
Re: cometic gaskets [Re: Quicktree] #1551083
12/21/13 01:00 PM
12/21/13 01:00 PM
Az
Crizila Offline
Crizila  Offline
Az
I just did the outsides to address any irregularities on the block / head surfaces. Assumed the other surfaces ( between layers ) would be good.
Fastest 300
Re: cometic gaskets [Re: Crizila] #1551084
12/21/13 02:45 PM
12/21/13 02:45 PM
Renton Washington
Triple Threat Offline
Renton Washington
yes
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: cometic gaskets [Re: Quicktree] #1551085
12/21/13 02:53 PM
12/21/13 02:53 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I've always taken them apart at the rivets and sprayed both surfaces of all 3 parts with 3M #99 adhesive.
Re: cometic gaskets [Re: Duner] #1551086
12/21/13 03:05 PM
12/21/13 03:05 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Sprayed a nice light coat on the outside of the head gaskets. They are the ones on my old 440 and they are still on there working good in my buddies Duster that we put my old 440 in. I built the eng in 2005. Ron
Re: cometic gaskets [Re: 383man] #1551087
12/21/13 03:21 PM
12/21/13 03:21 PM
Q
Q
i sprayed them all just to be sure, thanks
Re: cometic gaskets [Re: Quicktree] #1551088
12/21/13 04:40 PM
12/21/13 04:40 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've never sprayed mine per Cometics instructions I did spray a pair for a customers motor per thier instructions , there Cometic head gaskets where in bad shape, some of the nitrile rubber had worn off some of the steel gaskets but I did as ask and they didn't leak on a true 14.9 to 1 compression bracket motor I sprayed them on all sides by removing the exteranl rivets and sprayed away
Re: cometic gaskets [Re: Crizila] #1551089
12/21/13 08:18 PM
12/21/13 08:18 PM
MN
hemidup Offline
hemidup  Offline
MN
I did mine the same way and for the same reasons.
Jerry Williams.
Re: cometic gaskets [Re: hemidup] #1551090
12/21/13 08:51 PM
12/21/13 08:51 PM
Cleveland, Ohio
BB73Challenger Offline
Cleveland, Ohio
I did NOT spray anything per instructions.
New heads and clean smooth deck surface.
No leaks.
I have heard of copper spray for re-use.
Re: cometic gaskets [Re: BB73Challenger] #1551091
12/21/13 09:19 PM
12/21/13 09:19 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
No leaks.
exactly...No need to spray the head gaskets but I do believe you need a special surface for cometics gaskets.
Re: cometic gaskets [Re: Sammy] #1551092
12/21/13 11:47 PM
12/21/13 11:47 PM
Washington
skrews Offline
skrews  Offline
Washington
Hylomar spray FTW.
Re: cometic gaskets [Re: skrews] #1551093
12/21/13 11:54 PM
12/21/13 11:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Brand new with proper deck and head surfaces on my SB, no spray. They leaked until I through a can of stop leak in it. Never leaked again. BB same set up and machine work , no spray, no leaks. When I reused them on the BB I sprayed every side, no leaks. The SB is blown 12 lbs, the BB is 14.8-1. Both are studded
Doug
