Is there an engine to chassis/body ground strap on AAR
#1550818
12/21/13 02:30 AM
12/21/13 02:30 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I have studied a lot of pictures and cant seem to find one, did they utilize one? Were there problems due to not running one? Wouldn't it improve the electrical system if one/some were added?
Thanks in advance, Kevin
Careful, your character's showing!
Re: Is there an engine to chassis/body ground strap on AAR
[Re: Alaskan_TA]
#1550820
12/21/13 11:54 AM
12/21/13 11:54 AM
mopar346
As do most, but no other engine to chassis ground strap, interesting.
Thank you
[Re: mopar346]
#1550823
12/22/13 04:50 AM
12/22/13 04:50 AM
Posts: 75,059 U.S.S.A.
JohnRR
U.S.S.A.
Thank you
The battery cable to body started in 70 , 69 down had a ground strap for the engine to firewall , no lead from the battery cable to the core support.
[Re: JohnRR]
#1550824
12/22/13 09:28 AM
12/22/13 09:28 AM
mopar346
Maybe on Mopars, but other cars had both prior to 70 not sure when they started I just know I've seen them.
[Re: Seventythree]
#1550825
12/22/13 12:14 PM
12/22/13 12:14 PM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
73/74 has an additional ground strap that connects to the firewall.
Plus 72
[Re: mopar346]
#1550826
12/22/13 01:40 PM
12/22/13 01:40 PM
JohnRR
U.S.S.A.
An AAR is a MOPAR , correct ???
I didn't see the question being asked pertaining to a Ford or GM product ....
[Re: JohnRR]
#1550827
12/22/13 04:05 PM
12/22/13 04:05 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Careful John Santa is always watching!!!!
[Re: RJS]
#1550828
12/22/13 07:29 PM
12/22/13 07:29 PM
mopar346
You're correct John, I guess I am a lot more aware of ground straps since building a CJ, they have notoriuosly bad grounds that cause all sort of electrical gremlins.
[Re: mopar346]
#1550829
12/22/13 08:38 PM
12/22/13 08:38 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
If you paint them up and not make an effort on the grounding all makes and models will have you In your case make sure the tail light housings are grounded well or you'll be pulling them back out also..{there was a dedicated ground strap on the left,rear tail light housing not the right}...
Anyhow,the factory obviously saw an error in their ways and added the engine strap after a year or two past 70...If it bothers you add one back there and keep the grounding point low on the firewall so you can't see it...Unless you plan on having someone with a mirror climb in there at a show and cry foul on you...
