ABS plastic repair #155062
11/22/08 06:30 PM
11/22/08 06:30 PM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
I need to repair a few broken off molding tabs on a 70 cuda grille. These are cleanly broken off, they are too small or delicate to plastic weld back on.
I remember that someone posted here, that there is a solvent for ABS that can be used to join pieces that fit toghether well. It basically patially dissolved the plastic and fused it toghether.
Anyone remembers what its called and where to buy it?
Re: ABS plastic repair [Re: Barnabas_Kriss] #155063
11/22/08 07:07 PM
11/22/08 07:07 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It's called MEK (Acetone works to). Mix up some in a glass jar with some shavings of ABS (old grille pieces work well) and let it sit overnight (it will melt into goo) you want to end up with a mix that's something roughly the consistancy of wet peanut butter. Prep the edges of both pieces of the part by sanding them to a beveled edge, point the edges together aligning them and use clear packing tape to secure them and keep them aligned from the underside. Smear a nice pile of the goo into the new joint on the top side until it's piled high like a weld in metal. Let it dry a couple days, sand smooth. For thicker parts do the same process on both sides repeating the process the same way.
<img src="/ubbthreads/images/graemlins/Twocents.gif" alt="" />
Here's an ancient Moparts thread as well Moparts Grill Repair
Re: ABS plastic repair [Re: ScottSmith_Harms] #155064
11/23/08 10:05 AM
11/23/08 10:05 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Barnabas -
Check this link out for 70 grill repairs.
http://www.moparmusclemagazine.com/techa...pair/index.html
Re: ABS plastic repair [Re: larry4406] #155065
11/23/08 11:19 AM
11/23/08 11:19 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Find locktite 401 superglue it will hold anything ive fixed a few taillights and grills with it
Chrysler Firepower
Re: ABS plastic repair [Re: Barnabas_Kriss] #155066
11/23/08 09:55 PM
11/23/08 09:55 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Use the grille pieces melted in mek. It's the best fix out there. Make sure the pieces are clean and have no paint on them. Make it like described-peanut butter like. It may take a day or so to melt the plastic and get the mek to flash off enough for the right consistency. It takes about a full week to flash off all the solvent so be patient!!!! I just restored a 1970 Charger R/T grille that had holes on from foglamps and broken pieces. It came out very nice...I will look for the pics...but in the meantime check it out your view of the beast under construction
Re: ABS plastic repair [Re: ThermoQuad] #155067
11/23/08 10:09 PM
11/23/08 10:09 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What do you mean by the flash off all the solvent. Is there a mixing ratio of MEK to ABS? Whould things happen faster if you ground the ABS up?
BTW, I spy a Willwood box in the picture Tom. Anything interesting with that build?
Re: ABS plastic repair [Re: autoxcuda] #155068
11/23/08 10:15 PM
11/23/08 10:15 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The flash off = The MEK/Acetone will evaporate from the melted plastic. Time varies with the initial mixture, temperature, and other environmental variables.
Bottom line, one day, 3 days, a week, you'll know when it's ready to sand when the plastic returns to a hardened state, if it's not fully cured it can gum up while being sanded.
When you break down ABS this way it does change it's chemical composition somewhat, it will lose some of it's "stiff" properties and stay just a tad to the flexible side (a good thing when fixing cracked/stressed areas) so don't expect it to return to a rock hard state, just close to it.
Also keep in mind that the glueing or welding portion of a plastic repair job is the easy part, the real, skill, time, and effort falls into the sculpting, sanding, priming, painting, etc. Just like body work in miniature. Practice, practice, practice..
Re: ABS plastic repair [Re: ScottSmith_Harms] #155069
11/23/08 10:28 PM
11/23/08 10:28 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I'm in the process of doing my 68 charger grill and It was recommended to me to use 3m 8115 panel bonding adhesive. I did my first pieces today and while not fully cured yet, it holds like a rock. I replaced the fins and they are so fragile. I can't believe how good they are glued in there.
Re: ABS plastic repair [Re: Pool Fixer] #155070
11/23/08 10:35 PM
11/23/08 10:35 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Fair warning to those using glues, powdered plastics,and other bonding agents (other than the ABS method I described). While using one of the above mentioned products may sound like the easy way to go, and will usually work to glue two parts together, most of it sands differently than the surrounding ABS material (softer/harder). This can lead to allot of fun getting an area sanded flat and level, especially in transitional areas.
Re: ABS plastic repair [Re: autoxcuda] #155071
11/24/08 12:38 AM
11/24/08 12:38 AM
ThermoQuad Offline
ThermoQuad  Offline
You can do lots of tricks with the goo...if you are in a hurry to have it ready you can grind it up but why work so hard???
As to the Charger... well...it's like my AAR as far as tires/suspension up, 440/4bbl iron head auto car. TTI, Firm Feel, RMS etc... 355 dana, 4w disc, corbeu seats, 5 pt seatbelts, etc etc etc. The 440 was built by some one who build nascar engines for one of the big dogs. Welded and gusseted K frame, frame ties, Front rear spring boxes & more, Blacked out front rear incl hood...beastly
Re: ABS plastic repair [Re: ScottSmith_Harms] #155072
11/24/08 12:59 PM
11/24/08 12:59 PM
None
71rm23 Offline
71rm23  Offline
None
MEK (Methyl Ethyl Ketone) works good. Stinks though-good way to clean sinuses Have it at work. Good info from Scott
Re: ABS plastic repair [Re: 71rm23] #155073
11/24/08 01:05 PM
11/24/08 01:05 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Fair warning, MEK is VERY BAD for you, don't breath it or get it on your skin, not unless you are interested in getting some nasty cancers.
Re: ABS plastic repair [Re: ScottSmith_Harms] #155074
11/24/08 01:27 PM
11/24/08 01:27 PM
ThermoQuad Offline
ThermoQuad  Offline
Good pt.
Acetone is not as nasty as mek but you still need to use adequate ventilation, nitrile gloves, safety glasses, long sleeves, no shorts and a respirator if you do not have adequate ventilation.
