Re: 440 into a duster [Re: 71yelladustr] #1550548
12/20/13 10:33 PM
12/20/13 10:33 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....or you could just build a 440 with the distributer in the back!
Re: 440 into a duster [Re: 71yelladustr] #1550549
12/20/13 10:39 PM
12/20/13 10:39 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Here's mine in a demon
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: 440 into a duster [Re: 67mprfan] #1550550
12/20/13 11:21 PM
12/20/13 11:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Where`s the rest of the car? looks nice........
Re: 440 into a duster [Re: 67mprfan] #1550551
12/21/13 02:49 AM
12/21/13 02:49 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
it's f-f-f-ford blue!!!
Re: 440 into a duster [Re: Thumperdart] #1550552
12/21/13 05:05 PM
12/21/13 05:05 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
It has a removable front end and working in a 1 car garage gets real tight
Re: 440 into a duster [Re: rebel] #1550553
12/21/13 05:07 PM
12/21/13 05:07 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
dare to be different
Re: 440 into a duster [Re: 67mprfan] #1550554
12/21/13 05:13 PM
12/21/13 05:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
WOW, You have a garage? Lucky you.............
Re: 440 into a duster [Re: Thumperdart] #1550555
12/21/13 05:43 PM
12/21/13 05:43 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Here's mine with a 340 k-member and reworked factory motor mounts. You can sorta see where the fenderwells were cut out for the Hookers, but I was smart enough to get a set of Proparts headers from Mancini awhile back when they were only $500. I also have an original B-body radiator, Moroso oil pan and Milodon external oil pickup. It is all a very tight fit and a bear to change the starter or certain freeze plugs (of which I have done many!) If you are building a race car I would agree that cutting the inner fenders out is the best plan. If a street car I would get the 1-7/8 chassis headers.
A 440 A-body is easy 10's with a mild engine and it will go 400-500 runs with little maintenance.
Re: 440 into a duster [Re: cgall] #1550556
12/21/13 05:56 PM
12/21/13 05:56 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I was smart enough to get a set of Proparts headers from Mancini awhile back when they were only $500 It is all a very tight fit and a bear to change the starter
I have pro-parts and changing the starter is not bad
Re: 440 into a duster [Re: mcmopars] #1550557
12/21/13 06:56 PM
12/21/13 06:56 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
It ain't that hard to do,and the maintenance isn't bad IMHO... We have a 1971 Demon we have used both 383 and 440 engines in it. Motor plate,small Mopar starter and we used Pro Parts headers.Currently I'm putting the car back on the street,so I changed the headers to Schumacher headers and 2 1/2" exhaust,and put a 3.90 gear in the Dana.Only spark plugs that were a pain were 5 and 7.The radiator came out of a 71 Fury,and we use a trans cooler.To me,it's a easy swap.
Nautilus Racing-
