how do you find a bad hydraulic lifter? #155047
11/22/08 06:02 PM
11/22/08 06:02 PM
California
mickm Offline OP
mickm  Offline OP
California
find a broken engine... hmmm....
but seriously, i have a lifter on the left bank that sometimes ticks, sometimes doesn't. when i fire the engine up cold it almost knocks for a few seconds. so it seems that it is pumping up, but not staying there.
how do i isolate which one(s) it is?
Re: how do you find a bad hydraulic lifter? [Re: mickm] #155048
11/22/08 06:05 PM
11/22/08 06:05 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Pull the valve cover off and move each rocker arm by hand..see which one is more loose/has more play then the others ?
(that is what I've done on some ticky Hemi-6's I've had which are hard on lifters..)
Re: how do you find a bad hydraulic lifter? [Re: OzHemi] #155049
11/22/08 06:10 PM
11/22/08 06:10 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
If that doesn't work, try this. It gets a bit messy and you want to have a hose or extinguisher near.
Warn the engine so it will idle low and smooth. Start the car with the valve cover off. Grab a wooden handled hammer and press the handle end against the top of rocker on the pushrod end and lean on it. It should collapse the lifter some (tick, tick). Release the hammer, and the lifter will pump up. The bad one will take longer.
Re: how do you find a bad hydraulic lifter? [Re: RodStRace] #155050
11/22/08 06:13 PM
11/22/08 06:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
too bad it's a hemi and the valve covers are $$$ or you could just cut the top off one to keep the mess to a minimum
Re: how do you find a bad hydraulic lifter? [Re: JohnRR] #155051
11/22/08 06:15 PM
11/22/08 06:15 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I've got a few spare Hemi valve covers around..
They are just abit too long and too narrow though
Re: how do you find a bad hydraulic lifter? [Re: RodStRace] #155052
11/22/08 06:17 PM
11/22/08 06:17 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I had some bad lifters in my 383. we pulled the valve covers off, started the engine for a minute. as soon as we shut the engine off the bad lifters bled off instantly. didn't even have to touch them.
1981 Dodge D150 360 auto
Re: how do you find a bad hydraulic lifter? [Re: basketcase] #155053
11/22/08 06:33 PM
11/22/08 06:33 PM
BDW Offline
BDW  Offline
If your going to pull it apart, why not replace them all?
Re: how do you find a bad hydraulic lifter? [Re: BDW] #155054
11/22/08 06:56 PM
11/22/08 06:56 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
how many miles are on the engine? usually a lifter bleeds off because of a smal piece of guck in it. Try running a qt of ATF or Rislone with your next oil change. That will clean the varnish and guck out.
I am truckless..
Re: how do you find a bad hydraulic lifter? [Re: 340SHORTY] #155055
11/22/08 08:13 PM
11/22/08 08:13 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have a tool so you can change out the lifter without removing the intake. Mike
Re: how do you find a bad hydraulic lifter? [Re: 340SHORTY] #155056
11/22/08 09:10 PM
11/22/08 09:10 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Try running Rislone with your next oil change.
Seen it work before
Re: how do you find a bad hydraulic lifter? [Re: rrunner] #155057
11/22/08 10:12 PM
11/22/08 10:12 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Use a stethascope to pinpoint which one.A long piece of hose will get you close.
Re: how do you find a bad hydraulic lifter? [Re: 340SHORTY] #155058
11/23/08 02:01 AM
11/23/08 02:01 AM
California
mickm Offline OP
mickm  Offline OP
California
not more than a few thousand miles. wasn't there at first, it's a more recent thing. i will give that a try...
Re: how do you find a bad hydraulic lifter? [Re: BDW] #155059
11/23/08 02:03 AM
11/23/08 02:03 AM
California
mickm Offline OP
mickm  Offline OP
California
well, no plans to pull it apart just yet. the cam and lifters, springs and all are new, only a few thousand miles.
so if i can just figure out which one it is and replace it, that would be the ticket!
Re: how do you find a bad hydraulic lifter? [Re: mickm] #155060
11/23/08 11:35 AM
11/23/08 11:35 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
not exactly what you want
both this video is worth a look:
http://video.google.com/videoplay?docid=-8762172118089635709
does anyone have one of the old hydraulic lifter test stands that Chrysler, Ford or GM used to have in the specialized tool catalogs?
I ask to be able to have a
Brand name or official part number for eBay searches
did you know that a
Rhoads style hyd lifter
has a flat machined on purpose to the internal piston outside diameter to cause it to leak down quicker, but in a repeatable way?
http://tinyurl.com/6bglcp
http://tf.tribes.cc/telfort/px/url/287/p...p;RS=PN/5623898
if you have trouble seeing the USPTO drawings
which are TIFF files
download and use the
free Apple Safari for Windows
browser program which has good tiff support built right in
Re: how do you find a bad hydraulic lifter? [Re: mickm] #155061
11/23/08 02:44 PM
11/23/08 02:44 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
look inside a SBC, flat cam also!
