Stubby 727 #155020
11/22/08 05:39 PM
11/22/08 05:39 PM
GoDartGo Offline OP
GoDartGo  Offline OP
pleas tell me I can use regular yoke after I unbolt this one.
Re: Stubby 727 [Re: GoDartGo] #155021
11/22/08 06:08 PM
11/22/08 06:08 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
that would be a no!
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Stubby 727 [Re: GoDartGo] #155022
11/22/08 06:09 PM
11/22/08 06:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what do you nean , a slip yoke ??
if so what the guy above me said ... nope
Re: Stubby 727 [Re: JohnRR] #155023
11/22/08 06:14 PM
11/22/08 06:14 PM
GoDartGo Offline OP
GoDartGo  Offline OP
that would be a no!
DANG I didn't think so.
see ya in Trannys for sale.
Re: Stubby 727 [Re: GoDartGo] #155024
11/22/08 06:46 PM
11/22/08 06:46 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I need that tranny... too far away..
I am truckless..
Re: Stubby 727 [Re: 340SHORTY] #155025
11/22/08 07:03 PM
11/22/08 07:03 PM
scratchnfotraction Offline
I used one like that in a 68 Dart
I just used a drive shaft with a slip yoke
worked good and bolted right in with a drive shaft change
Re: Stubby 727 [Re: scratchnfotraction] #155026
11/22/08 07:30 PM
11/22/08 07:30 PM
Kissimmee Fl.
Kissimmee Fl.
dont know how right behind the rear seal is a roller bearing no way a slip yoke would slid in the tail housing unless you are talking about making a drive shaft with a slip joint like they use in a truck.
Re: Stubby 727 [Re: dusturbd340W5] #155027
11/22/08 08:01 PM
11/22/08 08:01 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
THE ONLY way to use that trans .. is to put on a tail housing and output shaft from a "regular" trans.
Re: Stubby 727 [Re: dusturbd340W5] #155028
11/22/08 09:05 PM
11/22/08 09:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think thats what he did if I read it correctly
Re: Stubby 727 [Re: JohnRR] #155029
11/22/08 09:18 PM
11/22/08 09:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Stubby 727 [Re: MoparforLife] #155030
11/22/08 11:48 PM
11/22/08 11:48 PM
GoDartGo Offline OP
GoDartGo  Offline OP
and that will bolt right up? no modifications?
the 727shorty I have is in very good cond. and I would like to use it for my Dart.
Re: Stubby 727 [Re: GoDartGo] #155031
11/23/08 04:22 AM
11/23/08 04:22 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
In order to install this parts the trans must come apart. Are you capable of doing that ?
Re: Stubby 727 [Re: dOrk !] #155032
11/23/08 11:03 AM
11/23/08 11:03 AM
GoDartGo Offline OP
GoDartGo  Offline OP
No, but I will learn. The shorty 727 was mostly a freebe. That'll be a good starting point.
I spent some time reading on Allpar last nite, and I'll get a 727's for Dummies book.
Re: Stubby 727 [Re: GoDartGo] #155033
11/23/08 11:36 AM
11/23/08 11:36 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
What did that trans come out of?
Re: Stubby 727 [Re: vdriver] #155034
11/23/08 11:39 AM
11/23/08 11:39 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
4wd truck with divorced transfer case.
Some 2wd trucks used it too IIRC.
Re: Stubby 727 [Re: GoDartGo] #155035
11/23/08 11:54 AM
11/23/08 11:54 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Be sure when you are changing the output shaft and housing that you don't mix front planetaries. There are three different spline angles on the front output shaft spline and planetary and there are combinations of different angles that will go together but will tear out the planetary spline very soon after. Check the tech section here for the three different angles.
Re: Stubby 727 [Re: slantzilla] #155036
11/23/08 11:54 AM
11/23/08 11:54 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I've had a few out of small motorhomes too..
Re: Stubby 727 [Re: OzHemi] #155037
11/24/08 03:07 PM
11/24/08 03:07 PM
yes,I built a drive shaft with a slip yoke like in a truck
I would install it and build a new shaft
way cheaper and quick
run what ya brung
Re: Stubby 727 [Re: slantzilla] #155038
11/24/08 04:40 PM
11/24/08 04:40 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I had the same thing in my '74 Power Wagon.
