Re: Stubby 727
[Re: JohnRR]
#155023
11/22/08 06:14 PM
11/22/08 06:14 PM
Posts: 1,527 Michigan
GoDartGo
that would be a no!
DANG I didn't think so.
see ya in Trannys for sale.
Re: Stubby 727
[Re: 340SHORTY]
#155025
11/22/08 07:03 PM
11/22/08 07:03 PM
Posts: 15,487 Florida
scratchnfotraction
I used one like that in a 68 Dart I just used a drive shaft with a slip yoke worked good and bolted right in with a drive shaft change
Re: Stubby 727
[Re: dusturbd340W5]
#155028
11/22/08 09:05 PM
11/22/08 09:05 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
dont know how right behind the rear seal is a roller bearing no way a slip yoke would slid in the tail housing unless you are talking about making a drive shaft with a slip joint like they use in a truck.
I think thats what he did if I read it correctly
Re: Stubby 727
[Re: MoparforLife]
#155030
11/22/08 11:48 PM
11/22/08 11:48 PM
GoDartGo
THE ONLY way to use that trans .. is to put on a tail housing and output shaft from a "regular" trans.
and that will bolt right up? no modifications? the 727shorty I have is in very good cond. and I would like to use it for my Dart.
Re: Stubby 727
[Re: GoDartGo]
#155031
11/23/08 04:22 AM
11/23/08 04:22 AM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
In order to install this parts the trans must come apart. Are you capable of doing that ?
Re: Stubby 727
[Re: dOc !]
#155032
11/23/08 11:03 AM
11/23/08 11:03 AM
GoDartGo
Quote: --------------------------------------------------------------------------------
No, but I will learn. The shorty 727 was mostly a freebe. That'll be a good starting point. I spent some time reading on Allpar last nite, and I'll get a 727's for Dummies book.
Re: Stubby 727
[Re: slantzilla]
#155036
11/23/08 11:54 AM
11/23/08 11:54 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
What did that trans come out of?
4wd truck with divorced transfer case.
Some 2wd trucks used it too IIRC.
I've had a few out of small motorhomes too..
Re: Stubby 727
[Re: OzHemi]
#155037
11/24/08 03:07 PM
11/24/08 03:07 PM
scratchnfotraction
yes,I built a drive shaft with a slip yoke like in a truck I would install it and build a new shaft way cheaper and quick run what ya brung
Re: Stubby 727
[Re: slantzilla]
#155038
11/24/08 04:40 PM
11/24/08 04:40 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
I had the same thing in my '74 Power Wagon.
