Indy 360-4 intake hood clearance #1550170
12/19/13 03:30 PM
12/19/13 03:30 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey Fellas,
So I was taking some pics for some parts I am selling and noticed the massive difference in height between the Victor 340 manifold I was running and the new Indy 360-4 intake I plan to bolt on...here is a pic
I run a cheater nitrous plate, a 1" spacer, and a 5" air cleaner. I also have an AAR cowl hood. I am wondering if this gargantuan intake is going to fit under there, or if I should start making plans for a taller hood?
Re: Indy 360-4 intake hood clearance [Re: mshred] #1550171
12/19/13 03:39 PM
12/19/13 03:39 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I haven't used either of those intakes, but it shouldn't be too hard to measure the difference in height between the two. If you know how much room you have now, it should be pretty easy to figure out the clearance.
I would probably look into losing the spacer, shorter air filter, or drop base housing before I would replace the hood...but I am cheap...haha
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Indy 360-4 intake hood clearance [Re: OUTLAWD] #1550172
12/19/13 03:50 PM
12/19/13 03:50 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I agree the hood really shouldn't have to be changed...But I run this car with a filter all the time, and I like to fit a healthy sized one on there too if you know what I mean so that the engine can breathe. I am unable to use a drop base filter because of my plate solenoids interfering. The car is in storage right now, otherwise I would have easy access to measure my current hood clearance.
I am just wondering if anyone has had any issues at all... To be honest, with the height of the plenum on the Indy, I would think it shouldn't even need a spacer- its a long way down looking at the top lol
Re: Indy 360-4 intake hood clearance [Re: OUTLAWD] #1550173
12/19/13 03:50 PM
12/19/13 03:50 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Don't need the spacer I only run the 1/2 to clear the 50cc pumps.
Re: Indy 360-4 intake hood clearance [Re: Scamp408] #1550174
12/19/13 04:00 PM
12/19/13 04:00 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I use the indy on my 408. aircleaner just cleared 6 pak hood using a 4150 and a 14" air cleaner with drop base. I now have a problem getting a dominator with a 16"x3.5 moroso air cleaner to clear. the 16" has a 3/4 dropbase. looks like i will have to trim 1" from the drop base and 1" from the intake carb flange. grrrrr
Re: Indy 360-4 intake hood clearance [Re: mshred] #1550175
12/19/13 05:00 PM
12/19/13 05:00 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Wow I thought my Victor 340 was a large intake. Heck, looks more like a performer when compared to that monster.
Re: Indy 360-4 intake hood clearance [Re: 80fbody] #1550176
12/19/13 06:49 PM
12/19/13 06:49 PM
Renton Washington
Triple Threat Offline
Renton Washington
Ditch the Spacer and run a shorter air cleaner if needed. 5" is excessive.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Indy 360-4 intake hood clearance [Re: Triple Threat] #1550177
12/19/13 06:59 PM
12/19/13 06:59 PM
an8sec70cuda Offline
Lose the spacer. Hope you don't end up in the same situation I was in a while back. Get a big new intake that makes more power way up top, but you lose so much lowend torque that it never runs worth a crap at the track.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Indy 360-4 intake hood clearance [Re: an8sec70cuda] #1550178
12/19/13 07:14 PM
12/19/13 07:14 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I like having the 5" air cleaner since I have the space for it right now. Obviously if I have to get something thinner I will, but I don't want less then 3" of air cleaner. I am a firm believer in running with an air cleaner to keep the engine clean (and my car slowed down taking it off this year) and if I am going to do that mine as well put the biggest filter on to allow the max amount of air to pass through.
Chip, what manifold did you switch too? Low end might be affected I am thinking as well, but with a loose converter like I have (5500) I would imagine the car will be above the weak point of the manifold (if there is some weakness in bottom end power that is...I have no idea what the power curve is like on these manifolds).
Re: Indy 360-4 intake hood clearance [Re: mshred] #1550179
12/19/13 07:42 PM
12/19/13 07:42 PM
Matt...I have a hemi, but I switched to a larger cast manifold (Indy 426-4). Has more plenum and runner volume than the Ray Barton manifold I had been running. Both single dominator manifolds.
The bigger manifold was stronger up top, but it never made up for what it lost down low. 60 foot slowed 1/2 a tenth! I never expected my 572" motor to be affected like that.
With the nitrous it might not be a big issue, but on motor you MIGHT be disappointed. It may run great, it just seems like a similar scenario to what I was in w/ mine is all.
It would have been better in my car if I had the converter loosened up a lot and was able to turn more rpm, but that's not at all what I wanted to do w/ it.
CHIP
Re: Indy 360-4 intake hood clearance [Re: an8sec70cuda] #1550180
12/19/13 08:35 PM
12/19/13 08:35 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey Chip, I know you run the hemi and in the past the RB stuff, but I wanted to hear your experience with it anyways since it might play out similar.
I got the manifold with the heads. To be honest, I have always assumed it was a top end package that had to go together, or atleast worked well together. I already have it, so I will try it and see. I hope you it still performs well. The car might eventually end up more of a bottle baby, but I still want it to be a fun all around car on the motor too.
I guess time will tell when I get to run it. But I have pretty much decided that a spacer on top of this giraffe like plenum might not be the best idea for hood clearance and performance
Re: Indy 360-4 intake hood clearance [Re: mshred] #1550181
12/19/13 09:24 PM
12/19/13 09:24 PM
Renton Washington
Renton Washington
I run a normal round 14x3" air cleaner on my car 24x7. Its not any faster with it off.
-Dustin
Re: Indy 360-4 intake hood clearance [Re: mshred] #1550182
12/19/13 10:59 PM
12/19/13 10:59 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
That's a nice table and chairs set. looks like we could do a Hot Wheels race too!!!
Lose the spacer, short filter. I run better with no filter but every car is unique and special in it's own way lol
Re: Indy 360-4 intake hood clearance [Re: Triple Threat] #1550183
12/19/13 11:00 PM
12/19/13 11:00 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'll see your indy.... and raise you!!
Re: Indy 360-4 intake hood clearance [Re: J_BODY] #1550184
12/19/13 11:07 PM
12/19/13 11:07 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
We ran this indy intake/dominator on our W5 set up. Just had clearance to run an UNI air cleaner with our 5" cowl hood.
Re: Indy 360-4 intake hood clearance [Re: Triple Threat] #1550185
12/19/13 11:24 PM
12/19/13 11:24 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I only tried with it off as I had a friend who harassed me that I was leaving e/t on the table...it was hillarious that the car slowed down instead when I tried though, he had nothing to say at that point lol
Re: Indy 360-4 intake hood clearance [Re: SpareParts] #1550186
12/19/13 11:26 PM
12/19/13 11:26 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
LOL yea thats the christmas wrapping table at the moment...my brother's gift to my 4 year old cousin is that lego car thing you see there
Like I said, with an already tall plenum, I don't see the benefit of the spacer, plus I will need hood clearance as there is going to be a cheater plate on top of there too
Re: Indy 360-4 intake hood clearance [Re: J_BODY] #1550187
12/19/13 11:26 PM
12/19/13 11:26 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Excuse my ignorance Jay, but what is a UNI air cleaner?
Re: Indy 360-4 intake hood clearance [Re: mshred] #1550188
12/19/13 11:55 PM
12/19/13 11:55 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Indy 360-4 intake hood clearance [Re: mshred] #1550189
12/20/13 12:56 AM
12/20/13 12:56 AM
K
KOS Offline
KOS  Offline
K
Ya ok did you tune the carb with the air cleaner on?if so shoulda tried rejetting it when you pulled it off ive never had a combo run slower and ive been doing this for 29yrs.maybe you have some type of turbulence issue with the hood your using then the air cleaner might help straighten it out and your using a very large breather but in my experience ive see usually a tenth to 2tenths when off especially when using a drop base style.i think there was only one experience when i seen no difference when i pulled the cleaner off but then again ive never been fortunate enough to run such a tall breather on any of my combos.
