Re: 4.15 stroke with a 7.1" rod?
[Re: barracuda7199]
#1549873
12/18/13 06:08 PM
12/18/13 06:08 PM
Posts: 596 Mass.
80fbody
Mass.
Deleted.
[Re: Cab_Burge]
#1549876
12/19/13 01:03 PM
12/19/13 01:03 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
What parts do you want to re-use? That makes a difference. If it is only the flexplate, maybe you could sell or trade the old one, and get an 8 bolt. Might be worth it if it gives you more choices on the more expensive components like the crankshaft. I think the jury is still out on the benefits of a long rod. I know of at least one very smart and succesfull builder who says a short rod makes more power because the piston has a quicker rate of acceleration away from TDC, thus intiating beter intake flow velocity at the point of maximum cam lift. I've had others tell me that the lighter piston and less side load of the long rod is better. Who knows?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: dogdays]
#1549879
12/19/13 02:42 PM
12/19/13 02:42 PM
Posts: 280 GEORGIA
barracuda7199
GEORGIA
It is possible to buy a 4.25" crank with 6 bolt flange, I don't know why the OP can't find them. And is a flexplate enough reason to change a project?
R.
It's not a good reason to change the project. Just trying to be smart where I spend the money. The ported 346 heads have to stay, single plane m1 and 850 DP. I know how these projects usually end up costing more than you plan I guess I am trying to compromise to much. What stroke would you go with in a 440 block? I have a couple 400 blocks but no intake pushrods etc....... It is a street car but I am not expecting or wanting a stock idle and it is not a daily driver. I want a 10 second street car period!
[Re: mopar dave]
#1549880
12/19/13 03:20 PM
12/19/13 03:20 PM
Posts: 168 Moparts
SSDart
Moparts
using the pipemax program I noticed if I input a shorter rod(6.300 to 6.123) it shows a 2hp increase. maybe that builder is correct with using shorter rods?
something like that......
[Re: barracuda7199]
#1549881
12/19/13 03:23 PM
12/19/13 03:23 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
You'd see more of gain by putting better heads on your current 440 than building a stroker and reusing those 346 heads.
[Re: an8sec70cuda]
#1549882
12/19/13 03:29 PM
12/19/13 03:29 PM
Posts: 280 GEORGIA
barracuda7199
GEORGIA
It's knocking in the bottom end. Some EZ heads are planned in the future after the shortblock is done.
[Re: barracuda7199]
#1549884
12/19/13 03:39 PM
12/19/13 03:39 PM
an8sec70cuda
Ahhh, gotcha. Like said earlier, K1 does have a 4.25" stroke crank w/ 2.2 journals and a 6 bolt flange...I have one. Talk w/ Dan at Performance Only. He'll hook you up w/ a badazz assembly done right.
[Re: Hemi_Joel]
#1549886
12/19/13 06:51 PM
12/19/13 06:51 PM
Posts: 4,210 New York
polyspheric
New York
It's not a "long rod", the ratio of 7.1:4.15 is shorter than the stock 440.
Boffin Emeritus
[Re: Performance Only]
#1549888
12/19/13 08:09 PM
12/19/13 08:09 PM
Posts: 280 GEORGIA
barracuda7199
GEORGIA
I have tried to call dan nothing but voicemails and no return call. Haven't thought of that cab. Going to pull the motor Monday and see what's up with it. Have to do some calling around and see if there is a shop near by that can do that. It sucks trying to hotrod on a budget!!
I'm sorry you had trouble reaching me by phone. I field anywhere from 25-40 phone calls a day plus the time I'm working in the shop, taking care of our local walk-in customers etc. etc. I don't remember not returning any phone calls where a message was left on my voice mail, I'm usually pretty good about that, Did you leave one? Again, sorry for your trouble.
Not trying to drag you thru the mud at all and I understand being busy! I'm not at the point of placing an order. Resend me your phone number and I will give you a call after the holidays. I would like to deal with someone close to me.
