Re: loose 750lb et change?
[Re: pittsburghracer]
#1549677
12/18/13 02:54 AM
12/18/13 02:54 AM
Posts: 62 middle tennessee
71RTC
middle tennessee
sorry it has a 727, 511 with indy -1cnc, engine made 766hp on motor and has a two stage plate with 150hp on each shot but those times were on motor (kept breaking the trans even on one shot), the engine is in my 71 challenger but the car is too nice to tear up so was gunna pull the 511 and put in this stealth, thanks it ran 6.40 at 108
[Re: Sport440]
#1549681
12/18/13 03:03 AM
12/18/13 03:03 AM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
4:88 gears will probably have to go. I ran a 4:30 gear in my NA Daytona but even that may be to deep for you with the NOS.
#1549682
12/18/13 03:06 AM
12/18/13 03:06 AM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What is the cage cert legal to?
#1549683
12/18/13 03:07 AM
12/18/13 03:07 AM
71RTC
middle tennessee
thanks I have a 4.10 I can try, never ran anything lower than that!!!
#1549685
12/18/13 08:59 AM
12/18/13 08:59 AM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
For 1/8 mile racing?
[Re: KatFysh]
#1549689
12/18/13 09:33 PM
12/18/13 09:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
isn't the "rule of thumb" 100lbs= 1/10 of a second? You are changing to a totally new ride though. You may be starting from scratch..
In a slower car thats true... but faster you get it takes more power... in his case starting with 2100# and add 700# then the driver thats 3000# or better so in the end it COULD be a 9.0 car But the car looks good ![](/ubbthreads/images/graemlins/thumbs.gif) ![](/ubbthreads/images/graemlins/wave.gif)
