06 Grand Cherokee 4.7L problem #154962
11/22/08 03:55 PM
11/22/08 03:55 PM
We don't make mistakes...
67500vert Offline OP
I've got a vibration through the engine, the back of the serpentine belt is slick with greasy stuff, and the fan blade wobbles when the engine is running. When I loosen the belt I can wobble the fan by hand quite a bit.
Does this sound like the water pump has bit the dust? How horrible of a job is that?
67 Coronet 500 Convertible Nemo me impune lacessit
Re: 06 Grand Cherokee 4.7L problem [Re: 67500vert] #154963
11/22/08 04:07 PM
11/22/08 04:07 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i noticed my fan clutch has a bit of wobble, but its running fine, i'll change the water pump at the same time i do the clutch while its all apart.
Re: 06 Grand Cherokee 4.7L problem [Re: ademon] #154964
11/22/08 04:24 PM
11/22/08 04:24 PM
yeah, starting to think it's a fan clutch problem, fan spins freely by hand, no tension on it. ugh.
Re: 06 Grand Cherokee 4.7L problem [Re: 67500vert] #154965
11/22/08 04:43 PM
11/22/08 04:43 PM
Thats what is sounds like. Hope that the clutch didnt take out ur water pump with all the pounding it probably put on it...
Good luck
Re: 06 Grand Cherokee 4.7L problem #154966
11/22/08 09:21 PM
11/22/08 09:21 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Sounds like the clutch is still fine if he has tu loosen the belt to wiggle it. If that is truly the case it is a bad water pump
