2004 Rear End into a 1998? #1549477
12/17/13 10:39 PM
12/17/13 10:39 PM
Bama
BigDawg72 Offline OP
Bama
I know the 04 has disk brakes, but other than that will the rear end's interchange? Both are 2 Wheel drive and 3.55 ratio 1500's. I thought I would pose the question before breaking out the old measuring tape.
Thanks!
Re: 2004 Rear End into a 1998? [Re: BigDawg72] #1549478
12/17/13 11:06 PM
12/17/13 11:06 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
'04 what? Dakota? ram? van? jeep? durango?
in the dakota/durango platform, I know that from 98 to 04, the pinion yoke changed from a traditional "u-strap over the U-joint" set-up that most of us are familiar with, to a flanged yoke where the yoke on the pinion was a flat 4-bolt flange, and there was a matching flat 4-bolt flange on the end of the driveshaft, where you simply bolted the 2 together.
the rear ends were otherwise interchangeable other than the yoke, so long as you were talking about dakota to dakota or durango to durango
**Photobucket sucks**
Re: 2004 Rear End into a 1998? [Re: 70Cuda383] #1549479
12/17/13 11:20 PM
12/17/13 11:20 PM
Bama
Bama
I guess that would help... Both are Ram 1500's
