Re: 8-3/4 Sure Grip Help
[Re: IB-CUDA]
#1548707
12/16/13 10:59 PM
12/16/13 10:59 PM
RapidRobert
(1) no need to mess with the adjustments with a ring gear gasket change. (2) 489 case I'm assuming. Yes when you pull the yoke you will need a new crush sleeve & torque to specs or the solid crush sleeve replacement & not sure what you have to do or not do when going with the solid sleeve but it is recommended to go with it I believe. EDIT only pull the axles out far enough so the pumpkin can come out. if you do need to remove the axles if the end seals need replacement holler
[Re: IB-CUDA]
#1548709
12/16/13 11:51 PM
12/16/13 11:51 PM
Posts: 12,233 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Although this is not a complicated job, the chances for mistakes the first time with no oversight, is high.
When you pull the axles out, try to hold them up off of the axle seals so as not to tear them. And either only pull them out a few inches to clear the center section or fully remove them and then change the axle seals. If you change the seals, it is best to use a certain seal driver to keep from damaging the seals. It can be home made.
You can change the pumpkin gasket with no other changes or adjustments.
If you change the pinion seal on a 489 gear case (check your last 3 numbers on the part number cast in the driver's side of the pumpkin) the yoke crushes the crush sleeve. So you can try replacing the yoke back where it began. (you are not supposed to do that, but it works okay occasionally).
Or you can replace the crush sleeve and reset the pre-load per the service manual.
If you decide to replace the crush sleeve with the solid tube, then you must set the bearing pre-load with shims.
Overall, it may be best to get some help on the first time you tackle this. It might just save time and money in the long run.
IHTH
Master, again and still
[Re: DaveRS23]
#1548710
12/17/13 03:03 AM
12/17/13 03:03 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
agree with above. nothing hard, but there's a couple of mine's along the way to beware of.
If you're running stock type, non-sealed axle bearings; When you re-assemble, don't forget to reset the axle end-play. A bad end-play setting can cost you a rear end.
[Re: StealthWedge67]
#1548711
12/17/13 03:09 AM
12/17/13 03:09 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Exactly , do not ASSuME that the end play is in spec , readjust it after pulling the axles.
[Re: IB-CUDA]
#1548718
12/19/13 09:04 PM
12/19/13 09:04 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Just a couple of things i would add I have changed hundreds of pinion seals on rear axles that have crush sleeve . If you ever worked in a Jeep/Chrysler Dealer you would not make much time changing crush sleeves for a simple pinion seal replacement . This is how we did it . 1.check the yoke for the backlash before you take it apart you can get a good feel for it by rotating back and forth softly . kind like rocking it. IF back lash is tight then proceed to next step if loose like more than tight wiggle . than the rear needs inspection. 2. with a bright light and a pick or finger nail count the threads protruding the pinion nut 3.record that thread count . 4. zip the nut off with impact gun while holding yoke with your free hand . 5. change seal . 6. clean rust off the threads and put 1-2 drops of red lock tight on the nut threads . tighten to 175 foot pounds no more ,no less while holding the yoke solid with a pinion holding tool you can make one out of long piece of flat stock so it locks against the frame or ground while you toque the nut. 7. Count the threads if same leave it alone. less tighten 1/8 turn until same threads show the key is to not over tighten. If any one who has rebuilt axles knows it takes over 200 ftlbs to start to crush the collar. IF this is done right no problems will come of it. PS stock cone bearings on the axles need to be greased .
1969 Dodge Charger
1969 Dodge Superbee
