97 dakota 42re pump failure or?
#1548470
12/16/13 03:29 PM
12/16/13 03:29 PM
Posts: 324 anacortes,wa
78asprin
anacortes,wa
My little v6 Dakota started acting up this morning. My girlfriend went out and started it, let it warm up, hopped in and as soon as she put it in reverse, it died. She put it in park, started it, put it in reverse and it did it again. I went out and tried it, it stayed running just fine, but its making a funny noise from up front. It wont do it in neutral or park, only in gear. I backed it up and drove it forward a few times and noticed it started leaking tranny fluid from the bellhousing area.... Any ideas on whats going on? Its a rebuilt 42re in a 97 v6 2wd dakota. It only has 23k miles or so on the rebuild.
Re: 97 dakota 42re pump failure or?
[Re: 78asprin]
#1548471
12/16/13 04:13 PM
12/16/13 04:13 PM
Guitar Jones
Torque converter. Probably took out the bushing in the pump as well.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: 71yelladustr]
#1548473
12/17/13 04:56 PM
12/17/13 04:56 PM
Posts: 25,790 Rio Linda, CA
John_Kunkel
Rio Linda, CA
'96-up has the milled flat pump drive, they don't crack as often as the slot drive but.......
