318 crank in a 340???? #154826
11/22/08 09:59 AM
11/22/08 09:59 AM
ST clair shores MI
moretoys Offline OP
moretoys  Offline OP
ST clair shores MI
Any real drawbacks besides a 340 crank being stronger.any other issues???same stroke, same beaing sizes,still steel crank.Is strength the only plus with a 340 crank??
Re: 318 crank in a 340???? [Re: moretoys] #154827
11/22/08 10:42 AM
11/22/08 10:42 AM
IN
ahy Offline
ahy  Offline
IN
I believe 318 transitioned to a cast crank in the 60's. The 340 transitioned to cast around 73/74. I'm sure somebody will provide exact dates and maybe some pics to help tell the difference.
That being said, a well preppped cast crank should be good for 350 - 400 HP so it depends on your build.
Re: 318 crank in a 340???? [Re: ahy] #154828
11/22/08 11:02 AM
11/22/08 11:02 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
balance will be different too.
Don't be the exception.
Re: 318 crank in a 340???? [Re: Supercuda] #154829
11/22/08 11:05 AM
11/22/08 11:05 AM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
I thought they were both neutral balanced
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: 318 crank in a 340???? [Re: 70dart360] #154830
11/22/08 11:14 AM
11/22/08 11:14 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Nuetral balanced means the rotating assembly needs no external balancing. Balance is slightly different (318 to 340) due to heavier pistons, etc. Same holds true for 305 to 350 chev. The difference is not great but should be rebalanced for different displacement.
Re: 318 crank in a 340???? [Re: buildanother] #154831
11/22/08 11:45 AM
11/22/08 11:45 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
The 318 crank went cast in 1973. Forged just like the 340 until then
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 318 crank in a 340???? [Re: 69L78Nova] #154832
11/22/08 12:45 PM
11/22/08 12:45 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
There are actually part numbers for cast cranks in 318's starting in 67 IIRC.
It's a common myth that 318's were steel cranks.
I've never torn down a LA family 318 that wasn't cast
Re: 318 crank in a 340???? [Re: buildanother] #154833
11/22/08 02:42 PM
11/22/08 02:42 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
mallory metal will have to be added to the crank to allow for the heavier 340 pistons...
finding lighter 340 pistons will help.....so will lighter rods...
Tony
70 AARCuda Vitamin C
Re: 318 crank in a 340???? [Re: 69L78Nova] #154834
11/22/08 02:57 PM
11/22/08 02:57 PM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
untrue...I have pulled apart MANY 68-72 vintage 318s and they all had cast cranks...
Re: 318 crank in a 340???? [Re: moretoys] #154835
11/22/08 03:02 PM
11/22/08 03:02 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
my 68 has a steel crank..i have the casting numbers somewhere, it even looks different..kinda rough in some places..
Re: 318 crank in a 340???? [Re: dave571] #154836
11/22/08 03:13 PM
11/22/08 03:13 PM
ST clair shores MI
moretoys Offline OP
moretoys  Offline OP
ST clair shores MI
Is the general rule of thumb about cast crank having the thicker balancer gone??
Re: 318 crank in a 340???? [Re: moretoys] #154837
11/22/08 03:21 PM
11/22/08 03:21 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
All 318's were neutral balanced whether cast or forged shafts. As was the 273.
Re: 318 crank in a 340???? [Re: moretoys] #154838
11/22/08 04:09 PM
11/22/08 04:09 PM
dave571 Offline
dave571  Offline
It's a general rule that never applied to 318's or 273's.
As mentioned, 318s are neutral ballanced with either cast or forged crank.
Here are some part numbers
year cid material cast#/forge#
64-67 273 forged 2128278, 2128869, 2205700
68-69 273 cast 2658268, 2658393
67-73 318 cast 2658278, 2658393
74-86 318 cast 2658278, 2658393, 3462387
2658391
68-72 340 forged 2532457, 2843868
73 340 cast 3462387
71-86 360 cast 3418640, 3418641, 3418642
Re: 318 crank in a 340???? [Re: dave571] #154839
11/22/08 06:14 PM
11/22/08 06:14 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
If you can find a 318-3 truck block, that'll have a forged crank.
Not so sure the "limit" on a cast crank is only 400 FWHP either...... ...but I cant say for certain as Ive never torn a 500HP LA down to check...
Re: 318 crank in a 340???? [Re: Moparmal] #154840
11/23/08 01:46 AM
11/23/08 01:46 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I have had a couple of 318 cranks from trucks that were forged steel. Look for the end throws of the rod journals. A steel 318 will not have the 1" hole drilled through the journal and a 340 steel shaft will. They can be balanced to fit in a 340 and work just fine. They are all internally balanced with no counter weight on the balancer or converter.
