Will a 8 3/4 Live?
#1548237
12/16/13 11:33 AM
12/16/13 11:33 AM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
My son's making changes to his 67 Dart. He will eventually be going to a Gen3 Hemi w/Mods. This is a street car. He will be running Cal Tracs, TKO 600 5 spd and will use a 27 x10.5 ET Street tire. He was told to put a Back Brace on it and it will use a clutch posi. Opinions please. thx matt
[img] [/img]
Re: Will a 8 3/4 Live?
[Re: clonestocker]
#1548239
12/16/13 11:40 AM
12/16/13 11:40 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I ran my race car with a stock 8 3/4 with a posi and it lasted 600 passes... but the car was light leaving at 5000+ rpm.... if he puts the back brace and the carrier cap or caps it would be fine for a long time... weight is what kills them
[Re: Cab_Burge]
#1548241
12/16/13 01:04 PM
12/16/13 01:04 PM
Posts: 1,178 Indy
FlyFish
Indy
After putting Caltracs on my car (stroked small block, 5k converter), it crushed the axle tubes at the spring perches on my 8 3/4. I switched the housing out for a Moser MO875 fabricated housing with a back brace...everything has been great since. This is on my 3200# Barracuda street/strip car that runs mid 10's.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: BradH]
#1548243
12/16/13 01:46 PM
12/16/13 01:46 PM
dogdays
www.doctordiff.comTake all the $ you were going to spend on back bracing, nodular or billet caps, etc and just buy a D60. You'll only have to do it once. R.
[Re: FlyFish]
#1548244
12/16/13 01:47 PM
12/16/13 01:47 PM
BradH
... I switched the housing out for a Moser MO875 fabricated housing with a back brace...
I looked at one of those, too, but started thinking putting any more money into an 8.75" setup was simply taking money away from what it would cost to upgrade to a Dana 60.
If I came across one cheap enough, I'd probably try it. But at the price I recall them selling for, it was a tough sell.
[Re: MR_P_BODY]
#1548246
12/16/13 02:28 PM
12/16/13 02:28 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
The 8 3/4 in your son's '67 Dart has several things going for it. 1) the '67 is one of the lightest A-bodies 2) the tires he wants to use are going to be a limiting factor in terms of bite and therefore stress 3) this is supposed to be a "street car" and banzai launches should not be every launch particularly if he wants to keep his license 4) since he is using a stick, even if he breaks the rear he won't have 727 parts coming through the floor from a rolled sprag That being said, I am a real beleiver in the brute strength of the Dana 60 when needed. I have never raced with anything else and never will
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: BradH]
#1548247
12/16/13 05:07 PM
12/16/13 05:07 PM
Posts: 1,178 Indy
FlyFish
Indy
Yeah, just the housing is not too expensive. I actually got a heck of a deal on mine because they had one that was special ordered and the customer backed out. Instead of scrapping it, they offered it to me for a much reduced price (since it was not exactly what I had asked for)...all I had to do was a little cutting and welding to make it fit. For me, it was much cheaper than going to a Dana (I could use my axles and pumpkin), but I know someday I might have to make the switch...but I think I'll be safe since I foot-brake.
[Re: Biginchmopar]
#1548249
12/16/13 05:43 PM
12/16/13 05:43 PM
MR_P_BODY
It will break - PERIOD!!!
I guess I better sell my 8 3/4... its only been 1.19 60'... with BIG slicks... but the car is light, with the street tires(even the MT EZ Streets) its gonna have some spin.... but I guess there is plenty on here that cant build a diff... dont dead hook ANY car.... you will also notice that you dont see the guys saying they blow the D60s... and they do on a regular basis
[Re: MR_P_BODY]
#1548252
12/16/13 07:21 PM
12/16/13 07:21 PM
Quicktree
Mike you are not doing an equal comparison, you have a after market aluminum housing a light car and not a bunch of power.
[Re: Quicktree]
#1548253
12/16/13 07:29 PM
12/16/13 07:29 PM
MR_P_BODY
Tony I made 600+ passes on a STOCK 8 3/4 with just a back brace... that was with 550hp in a heavier car than now by about 250# so that was close to 2700# and EVERY pass was off the trans brake
[Re: Quicktree]
#1548254
12/16/13 07:29 PM
12/16/13 07:29 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I'd bet he makes more than the O.P. is planning on. Like he said......weight kills them. Add a stick and I would not consider an 8 3/4. Add up a cap or caps , decent case , back brace and I have to agree that a Dana is a better alternative. But done correctly , an 8 3/4 can survive within certain parameters. My gut feeling is a heavy car that makes some oats or a stick shift that hooks would be outside of those.
[Re: Quicktree]
#1548255
12/16/13 07:31 PM
12/16/13 07:31 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
I don't want to hurt fealings or step on toes but with his set-up IT WILL BREAK! Any diff can break with enough abuse. I speak from experience 3800lbs 69 Roadrunner with a 10" slick, 5 speed, Cal-Tracs, around 650lbs/ft torque. I have broke axles, bent things on a Dana 60. The 8 3/4 would have destoyed it self long, long ago.
[Re: Biginchmopar]
#1548256
12/16/13 07:34 PM
12/16/13 07:34 PM
Quicktree
I wouldn't recommend an 8-3/4 to anyone but everybody knows that.
