Re: 1978 M880 electrical system dead
[Re: 500ciDuster]
#1547944
12/15/13 11:32 PM
12/15/13 11:32 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Another thought... try wiggling the bulkhead connectors. That cured my dead electrical system on my 68 Barracuda. Which was followed by pulling the connectors and cleaning.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: MadMez]
#1547947
12/16/13 04:57 PM
12/16/13 04:57 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Check the amp gauge as said.They burn and do all kinds of weird stuff.I eliminated every one in the 4 70s trucks I had.One did what yours is doing.I just installed a volt meter in them.My 83 also had a burnt up ignition switch at the bottom of the column.Rocky
Chrysler Firepower
[Re: therocks]
#1547948
12/16/13 09:52 PM
12/16/13 09:52 PM
Posts: 5,948 British Columbia
chrisf
British Columbia
that's the first place i go too. you will find it a nice shade of toasty brown and black. the terminals should be melted right into the plastic cluster too.
[Re: chrisf]
#1547949
12/19/13 01:58 PM
12/19/13 01:58 PM
Posts: 6,018 Morningside
AdventurerSport
waaaay out there in left field
Morningside
Yup, fuse links, then bulkhead connectors, then amp gauge...any or all will cause this...good luck! JS (PROUD Owner of my Dad's 1976 Power Wagon W100 with factory original and working properly AMP gauge!)
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
[Re: AdventurerSport]
#1547950
12/19/13 05:37 PM
12/19/13 05:37 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
does this M880 still have the dial switch on the dash that controls the blackout lighting? The wiring is often all done in what looks like brown lamp cord, with little numbered aluminum tags crimped to the connections?
I know this dial switch caused a lot of issues on a friends truck. It would not crank, or fire at times, or other odd electrical issues would pop up.
He carefully removed all the military add on harness, and restored to the factory and the problems went away.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: MadMez]
#1547953
12/24/13 12:30 AM
12/24/13 12:30 AM
Posts: 1,404 northeast ohio
hulmule
northeast ohio
brother has one. military switch under dash/ on the dash got my brother stuck deer hunting. switch was bad.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
