1978 M880 electrical system dead #1547939
12/15/13 07:42 PM
12/15/13 07:42 PM
Slinger WI
MadMez Offline OP
MadMez  Offline OP
Slinger WI
My new plow truck has some kind of electrical issue. It quit running and asI was trying to figure out why I noticed the whole electrical system is dead. Nothing works, the headlights do not even turn on. Yes the battery is charged. If I jump yhe solenoid the engine turns over. Any one have a similar experience? Is there a common failure which would cause this?
Thanks for any help!
Re: 1978 M880 electrical system dead [Re: MadMez] #1547940
12/15/13 07:54 PM
12/15/13 07:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Start looking for a fusible link that's burned out. I don't know the system but if it has an amp gauge you might want to check the wiring at it also.
Re: 1978 M880 electrical system dead [Re: MadMez] #1547941
12/15/13 07:55 PM
12/15/13 07:55 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Check for a bad fusible link on the drivers side inner fender. A quick check is to slightly tug on the wires going to them and they will pull right apart if they are bad.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 1978 M880 electrical system dead [Re: MadMez] #1547942
12/15/13 08:27 PM
12/15/13 08:27 PM
places
79powerwagon Offline
places
C'mon Tim! It's a Dodge! Add more clean grounds! (after you check the usually by-passed fusible link)
Re: 1978 M880 electrical system dead [Re: 79powerwagon] #1547943
12/15/13 08:36 PM
12/15/13 08:36 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
My 79 would get a bad connection at the ampmeter and every thing would be dead
Re: 1978 M880 electrical system dead [Re: 500ciDuster] #1547944
12/15/13 11:32 PM
12/15/13 11:32 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Another thought... try wiggling the bulkhead connectors. That cured my dead electrical system on my 68 Barracuda. Which was followed by pulling the connectors and cleaning.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 1978 M880 electrical system dead [Re: GO_Fish] #1547945
12/16/13 12:49 AM
12/16/13 12:49 AM
Slinger WI
MadMez Offline OP
MadMez  Offline OP
Slinger WI
Hey! Fusable links, checking that will be better than crawling under the dash. Now that I'm old and well fed I do not enjoy that like I used to, and I never liked it!
Hey Eric, how is it going? We can only add so many grounds. The wiring on this truck looks like a Texas chain saw electrician worked on it. I'II be on it again next Saturday. Wish me luck.........
Re: 1978 M880 electrical system dead [Re: MadMez] #1547946
12/16/13 04:13 PM
12/16/13 04:13 PM
Slinger WI
MadMez Offline OP
MadMez  Offline OP
Slinger WI
OK, check this out. I stopped working on the truck Saturday at about 3:00. I left the key turned to accessory and a bunch of things turned on. Even though the battery was charged I left the charger on it. Nothing continued to happen Saturday and Sunday, I got home from my night job at about 11:00pm Sunday night, nothing was happening. At 7:00 this (Monday) morning I come out of the house to go to work. The truck is buzzing and the lights are on!
I run over to it and turn the key to off and shut of the lights. The buzzing stops and the lights go out. Just for fun I turn the key forward and the engine turns over. I'll try it again tonight but this is very odd.
Re: 1978 M880 electrical system dead [Re: MadMez] #1547947
12/16/13 04:57 PM
12/16/13 04:57 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Check the amp gauge as said.They burn and do all kinds of weird stuff.I eliminated every one in the 4 70s trucks I had.One did what yours is doing.I just installed a volt meter in them.My 83 also had a burnt up ignition switch at the bottom of the column.Rocky
Chrysler Firepower
Re: 1978 M880 electrical system dead [Re: therocks] #1547948
12/16/13 09:52 PM
12/16/13 09:52 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
that's the first place i go too. you will find it a nice shade of toasty brown and black. the terminals should be melted right into the plastic cluster too.
Re: 1978 M880 electrical system dead [Re: chrisf] #1547949
12/19/13 01:58 PM
12/19/13 01:58 PM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
Yup, fuse links, then bulkhead connectors, then amp gauge...any or all will cause this...good luck!
JS
(PROUD Owner of my Dad's 1976 Power Wagon W100 with factory original and working properly AMP gauge!)
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: 1978 M880 electrical system dead [Re: AdventurerSport] #1547950
12/19/13 05:37 PM
12/19/13 05:37 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
does this M880 still have the dial switch on the dash that controls the blackout lighting? The wiring is often all done in what looks like brown lamp cord, with little numbered aluminum tags crimped to the connections?
I know this dial switch caused a lot of issues on a friends truck. It would not crank, or fire at times, or other odd electrical issues would pop up.
He carefully removed all the military add on harness, and restored to the factory and the problems went away.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 1978 M880 electrical system dead [Re: hp383] #1547951
12/20/13 03:55 PM
12/20/13 03:55 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Is it a 24 volt system?
Re: 1978 M880 electrical system dead [Re: dart4forte] #1547952
12/20/13 04:12 PM
12/20/13 04:12 PM
Slinger WI
MadMez Offline OP
MadMez  Offline OP
Slinger WI
The truck still has the military switches and the wiring with those crimps. I am going to bypass the alternator gauge and check the fusible links to see if that helps.
The truck had an add on 24 volt system for the radios it carried but it is still a 12v system.
Re: 1978 M880 electrical system dead [Re: MadMez] #1547953
12/24/13 12:30 AM
12/24/13 12:30 AM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
brother has one. military switch under dash/ on the dash got my brother stuck deer hunting. switch was bad.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 1978 M880 electrical system dead [Re: hulmule] #1547954
12/26/13 10:58 AM
12/26/13 10:58 AM
Slinger WI
MadMez Offline OP
MadMez  Offline OP
Slinger WI
Thanks guys! It started to work all on its own. I am going to run a 10ga wire from the alternator to the starter relay to take the big load off the bulkhead connector and ammeter gauge. And hope it lasts till spring.
Re: 1978 M880 electrical system dead [Re: MadMez] #1547955
12/26/13 11:53 PM
12/26/13 11:53 PM
ohio
Sherminator Offline
Sherminator  Offline
ohio
Reach up and wiggle the amp gauge wires lights and other stuff on If voltage chances u can see it The post burn lose in gauge get a amp gauge for a school bus
