Does anyone make a 6 pack lift plate?? #1547644
12/15/13 02:39 AM
12/15/13 02:39 AM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
Lift the four barrel ones you see. Something that attaches to the intake and allows you to lift the engine for painting and such.
Thanks, Kevin
Careful, your character's showing!
Re: Does anyone make a 6 pack lift plate?? [Re: mopar346] #1547645
12/15/13 03:15 PM
12/15/13 03:15 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
You use the same 4bbl plate on a six pack manifold.
I fits fine.
Ron
Re: Does anyone make a 6 pack lift plate?? [Re: mopar346] #1547646
12/15/13 03:48 PM
12/15/13 03:48 PM
wyo
70 vcodecuda Offline
wyo
I used two of the lift plates along with the equalizer bar set up
twice the strength and all the adjustability
1970 Cuda V code 4speed Shaker 2009 Challenger RT 2003 Ram 2500 Quad Cab CTD
Re: Does anyone make a 6 pack lift plate?? [Re: 70 vcodecuda] #1547647
12/15/13 11:13 PM
12/15/13 11:13 PM
mopar346 Offline OP
mopar346  Offline OP
I wondered but never put it up to it. I am just not comfortable with the motor hanging by an aluminum intake, much less an eexpensive one, I may try the 2 plate trick.
Re: Does anyone make a 6 pack lift plate?? [Re: mopar346] #1547648
12/16/13 12:46 AM
12/16/13 12:46 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
I've used my 4 barrel lift plate with multiple holes to install my 440 Six Pack in and out a few times now.
I use top grade studs and nuts in the intake instead of bolts.
I was a little nervous at first and made sure everything was prepared to get the job done as quickly as possible.
I use it as a backup to my engine stand when working on the engine.
I will use it again.
Re: Does anyone make a 6 pack lift plate?? [Re: KillerBee] #1547649
12/16/13 01:00 AM
12/16/13 01:00 AM
mopar346 Offline OP
mopar346  Offline OP
Define top grade studs please.
Re: Does anyone make a 6 pack lift plate?? [Re: mopar346] #1547650
12/16/13 09:21 AM
12/16/13 09:21 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
It's been awhile since I bought the hardware at my local industrial hardware store but I believe it was grade 8 nuts and washers with B7 threaded steel rod.
I have also used just grade 8 bolts and washers.
