indy 360-1 odd valve size #1547612
12/15/13 01:26 AM
12/15/13 01:26 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
anyone know why indy used the 2.100 in. and 1.650 ex valve sizes? i'm more concerned about the odd 1.650 exhaust valve. why would they use that size when everyone else seems to use 1.60. whats the benefit with that large exhaust valve? seems like they would of had something like 2.08/1.60 as ryan once told me the 2.08 worked better than the 2.100 for some reason. anyway, just curious to what anyone knows about indys odd valve choices.
Re: indy 360-1 odd valve size [Re: mopar dave] #1547613
12/15/13 01:01 PM
12/15/13 01:01 PM
Mt Morris Michigan
Mt Morris Michigan
any cylinder head guru's out there have any opinions on why indy uses the 1.650ex valve while most others are using the 1.60?
Re: indy 360-1 odd valve size [Re: mopar dave] #1547614
12/15/13 01:06 PM
12/15/13 01:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
1.625" is common also.. the W-9 has one of the best
flowing exhaust ports out there and they run a 1.625"
Re: indy 360-1 odd valve size [Re: MR_P_BODY] #1547615
12/15/13 01:23 PM
12/15/13 01:23 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
The 1.65 is carry over from Batton w2. ( all an Indy head is old Batton stuff)
I run 1.60 in that head then Run 2.125-2.15" intake valve.
Re: indy 360-1 odd valve size [Re: W5DART66] #1547616
12/15/13 01:28 PM
12/15/13 01:28 PM
Mt Morris Michigan
Mt Morris Michigan
that looks like a better valve size ratio than what indy offers. what compression are you at with that valve size?
Re: indy 360-1 odd valve size [Re: mopar dave] #1547617
12/15/13 04:54 PM
12/15/13 04:54 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I had 2.15/1.60 in my 245s.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: indy 360-1 odd valve size [Re: 1967dartgt] #1547618
12/15/13 05:41 PM
12/15/13 05:41 PM
Mt Morris Michigan
Mt Morris Michigan
did you buy them new with those valves in them?
Re: indy 360-1 odd valve size [Re: mopar dave] #1547619
12/15/13 08:27 PM
12/15/13 08:27 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes I got them from shadydell that way.
Re: indy 360-1 odd valve size [Re: 1967dartgt] #1547620
12/15/13 09:05 PM
12/15/13 09:05 PM
Mt Morris Michigan
Mt Morris Michigan
ok, not sure the 1.650 valve hurts anything. I was just wondering why they choose that size. if I wanted a 1.60 valve, would it be possible to go down in size?
Re: indy 360-1 odd valve size [Re: mopar dave] #1547621
12/15/13 09:29 PM
12/15/13 09:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure if you have new seats put in
Re: indy 360-1 odd valve size [Re: MR_P_BODY] #1547622
12/15/13 09:54 PM
12/15/13 09:54 PM
BPE Offline
BPE  Offline
Call Indy and talk to Josh. I am pretty sure you can buy them in any form, since they make them from start to finish. So, if you want them with no seats or unfinished seats you could get them that way, but check with them first.
Rod
