what radiator will fit in a 42 dodge truck ?? #1547149
12/13/13 04:56 PM
12/13/13 04:56 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
just found out my radiator for my 42 dodge truck is shot. the local radiator shop wants anywhere from $1,100.00 to $1,700.00 to re-core the original. i don't want to spend that much on a radiator right now. i will have a stock late model 360 magnum in it. what do some people use in place of the original.
Re: what radiator will fit in a 42 dodge truck ?? [Re: 2abodymcodes] #1547150
12/13/13 05:00 PM
12/13/13 05:00 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Bought the biggest radiator Griffen makes for a Chevy truck for $210 shipped off eBay.
I sent some pictures to your profile email address.
Re: what radiator will fit in a 42 dodge truck ?? [Re: moparpollack] #1547151
12/13/13 06:59 PM
12/13/13 06:59 PM
Shelby, Ohio
2
Shelby, Ohio
thanks for the info and pics. what kind of truck is that in and what engine ?
Re: what radiator will fit in a 42 dodge truck ?? [Re: 2abodymcodes] #1547152
12/14/13 12:01 AM
12/14/13 12:01 AM
85086
Lil Herman
Lil Herman
85086
39 Plymouth pick up 360 la motor
Re: what radiator will fit in a 42 dodge truck ?? [Re: moparpollack] #1547153
12/14/13 02:26 AM
12/14/13 02:26 AM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
hey what about us, WE like pictures too
Re: what radiator will fit in a 42 dodge truck ?? [Re: Mopar Ron] #1547154
12/14/13 01:34 PM
12/14/13 01:34 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the best aluminum radiator prices are from speedway and they are delivered in one day....bob
Re: what radiator will fit in a 42 dodge truck ?? [Re: savoy64] #1547155
12/14/13 05:19 PM
12/14/13 05:19 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i cant say if you need the same radiator, but i would think its, probably the same. I just went through a radiator fitment problem with my 47 Desoto w/318. I bought a used aluminum universal fit radiator for a small block chevy, thinking it would work. I was very wrong. you might be able to get it to work if you used an electric fan. the inlet/outlet are to close together, I have the cut to fit hose kit and could not get it to work. the water pump sticks down to far. Its hard to find a radiator that is taller than it is wide for cheap. the only one I found and bought was this one-
sorry i cant get the link to work, speedway motors Item # 9175159
it fit great and looks great. I did easily make my own brackets.
Re: what radiator will fit in a 42 dodge truck ?? [Re: 65rbdodge] #1547156
12/14/13 08:15 PM
12/14/13 08:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Custom built aluminum vertical flow radiaors
http://www.streetrodstuff.com/Products/159/
Price is actually not bad for what you get.
Don't be the exception.
Re: what radiator will fit in a 42 dodge truck ?? [Re: Mopar Ron] #1547157
12/15/13 12:00 AM
12/15/13 12:00 AM
85086
Lil Herman
Lil Herman
85086
http://www.ebay.com/itm/Griffin-Aluminum...383&vxp=mtr
19"x31 holds a ton of coolant!
Re: what radiator will fit in a 42 dodge truck ?? [Re: moparpollack] #1547158
12/15/13 01:02 AM
12/15/13 01:02 AM
Mopar Ron Offline
Mopar Ron  Offline
Re: what radiator will fit in a 42 dodge truck ?? [Re: Mopar Ron] #1547159
12/15/13 09:27 AM
12/15/13 09:27 AM
moparx Offline
moparx  Offline
that is a pretty decent price for that summit rad.
