electronic distributor installation #154712
11/21/08 10:51 PM
11/21/08 10:51 PM
Anonymous OP
Anonymous OP
I installed a summit[SUM-850005-1/blue box] distributor in my 1968 440 motor[from a new yorker] 68 coronet.I have adjusted the timing several times and I have a high RPM miss that I did not have with the point distributor.Is it detrimental that I use a 2 field terminal alternator?I am currently using a new single field 55 amp alternator.Can I rebuild this unit to a 2 field or just purchase a new one and get on with my troubleshooting?
Re: electronic distributor installation #154713
11/21/08 11:04 PM
11/21/08 11:04 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The ignition system doesn't care what alternator you use of it you even use one as long as the battery maintains enough voltage to fire the ignition system. Check your grounds, check your battery voltage, check your connections, check your firing order and plug wire routing.
Re: electronic distributor installation [Re: MoparforLife] #154714
11/22/08 07:37 AM
11/22/08 07:37 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree.My kids 62 runs a single with the electronic reg replacement.He ran an MP dist for 5 years.Now has MSD digital and never misses.Rocky
Chrysler Firepower
