Are 8 3/4" Diff Center Sections Date Coded? #1547092
12/13/13 11:03 AM
12/13/13 11:03 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Is there any type of date coding on 8.75 rear differential center sections? 741 case if that makes a difference.Thanks
Re: Are 8 3/4" Diff Center Sections Date Coded? [Re: 44D6PAKCUDA] #1547093
12/13/13 11:43 AM
12/13/13 11:43 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I believe the assemble date is stamped in white paint on the drivers side of the pinion snout and I think the casting has a date cast into it but I cant swear to that, I will try to look at one later if no one confirms it.
Careful, your character's showing!
Re: Are 8 3/4" Diff Center Sections Date Coded? [Re: 44D6PAKCUDA] #1547094
12/14/13 05:20 AM
12/14/13 05:20 AM
Cab_Burge Online work
Cab_Burge  Online Work
Probally not considering how many where made and used and how long they made them
Re: Are 8 3/4" Diff Center Sections Date Coded? [Re: Cab_Burge] #1547095
12/14/13 09:11 AM
12/14/13 09:11 AM
Morningside, Long Island
scatcity Offline
scatcity  Offline
This ? 196th Day of 1971
Re: Are 8 3/4" Diff Center Sections Date Coded? [Re: scatcity] #1547096
12/14/13 09:13 AM
12/14/13 09:13 AM
scatcity Offline
scatcity  Offline
Gears of same..
Re: Are 8 3/4" Diff Center Sections Date Coded? [Re: scatcity] #1547097
12/14/13 09:18 AM
12/14/13 09:18 AM
scatcity Offline
scatcity  Offline
3:23 one legger pig...
Re: Are 8 3/4" Diff Center Sections Date Coded? [Re: scatcity] #1547098
12/14/13 09:33 AM
12/14/13 09:33 AM
scatcity Offline
scatcity  Offline
Wasted 3:23 worms...
Re: Are 8 3/4" Diff Center Sections Date Coded? [Re: scatcity] #1547099
12/14/13 09:37 AM
12/14/13 09:37 AM
scatcity Offline
scatcity  Offline
Last one. Though not a 741 as in your case but, yes, there are several date references on some. It appears that the gears in this instance were forged 6 days prior to installation in the case or at least in assembly / accountability process.
Re: Are 8 3/4" Diff Center Sections Date Coded? [Re: scatcity] #1547100
12/14/13 09:55 AM
12/14/13 09:55 AM
scatcity Offline
scatcity  Offline
253rd day of 1973 ...2:76 single legger...
Re: Are 8 3/4" Diff Center Sections Date Coded? [Re: scatcity] #1547101
12/14/13 09:59 AM
12/14/13 09:59 AM
scatcity Offline
scatcity  Offline
2:76 1973
Re: Are 8 3/4" Diff Center Sections Date Coded? [Re: mopar346] #1547102
12/19/13 03:58 AM
12/19/13 03:58 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Assembly date 10/23 in white paint, driver's side here:
Re: Are 8 3/4" Diff Center Sections Date Coded? [Re: kentj340] #1547103
12/19/13 04:03 AM
12/19/13 04:03 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Close up view showing it actually is white paint, even though it looks yellow at first glance.
