Tubing Bender Questions #1547027
12/13/13 12:18 AM
12/13/13 12:18 AM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
Anybody spend time behind the wheel of one of these things? I borrowed this from a friend and he said enjoy you'll get it figured out . Just bending the bars to tie the front cage bars to the frame rails. Are they simple enough that I won't go broke from buying tubing . Anything will help. thx matt
[img] [/img]
Re: Tubing Bender Questions [Re: clonestocker] #1547028
12/13/13 12:21 AM
12/13/13 12:21 AM
Tucson, Arizona
Tucson, Arizona
Here's where I'm at with the car. I hope I'll be able to thread the tube in in one piece. It will also have to bend over a little bit in side the car.
[img] [/img]
Re: Tubing Bender Questions [Re: clonestocker] #1547029
12/13/13 12:33 AM
12/13/13 12:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Your doing good so far also angle the bars
with a lesser angle instead of 90* bends for the front
its stronger
Re: Tubing Bender Questions [Re: MR_P_BODY] #1547030
12/13/13 12:41 PM
12/13/13 12:41 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Get your self an angle finder and a radius finder and info on lengths of pipe per angle and radius.This will minimize waste.Always leave a little extra on the tails for coping.
Re: Tubing Bender Questions [Re: B G Racing] #1547031
12/13/13 12:48 PM
12/13/13 12:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This and I use a isolating drum sander to fine tune
the end cuts for the final alignment and fit
Re: Tubing Bender Questions [Re: MR_P_BODY] #1547032
12/13/13 01:15 PM
12/13/13 01:15 PM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
copper pipe for fuel line ??
Re: Tubing Bender Questions [Re: bigdad] #1547033
12/13/13 03:00 PM
12/13/13 03:00 PM
Tucson, Arizona
Tucson, Arizona
It's aluminum w/overspray on it.
[img] [/img]
Re: Tubing Bender Questions [Re: clonestocker] #1547034
12/13/13 04:28 PM
12/13/13 04:28 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Gee Mr, Can I borrow that when you are done?
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Tubing Bender Questions [Re: Polarapete] #1547035
12/13/13 04:35 PM
12/13/13 04:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think I'll be selling my bender.. I'm done doing
chassis's
Re: Tubing Bender Questions [Re: MR_P_BODY] #1547036
12/13/13 09:17 PM
12/13/13 09:17 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Work slowly until you get the hang of it. It's way easier to put the tube back in and bend it some more than to unbend it. Have fun!
Brian
Re: Tubing Bender Questions [Re: '72CudaRacer] #1547037
12/14/13 06:53 PM
12/14/13 06:53 PM
Tucson, Arizona
Tucson, Arizona
Easing up on it but making progress. Piece of cake using tubing bender. Here's some pictures.
[img] [/img]
Re: Tubing Bender Questions [Re: clonestocker] #1547038
12/14/13 07:11 PM
12/14/13 07:11 PM
Q
Quicktree Offline
Quicktree  Offline
Q
why didn't you land that on the outside of the inner fender?like this
Re: Tubing Bender Questions [Re: Quicktree] #1547039
12/14/13 07:14 PM
12/14/13 07:14 PM
Q
Quicktree Offline
Quicktree  Offline
Q
actually you kind of split the difference. but what you did will work.
Re: Tubing Bender Questions [Re: clonestocker] #1547040
12/14/13 07:23 PM
12/14/13 07:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont want to tell you what to do but when you go
to pull your engine you are gonna have some issues..
the down bar at the front and the engine plate will
hit the plate mounts(put them on the rear side of the
plate) and the plate will hit the bars... move all
that now ...... if you want
Re: Tubing Bender Questions [Re: MR_P_BODY] #1547041
12/15/13 06:38 PM
12/15/13 06:38 PM
Tucson, Arizona
Tucson, Arizona
Mike, Thanks for your input. Here's another picture from the top. I think the other picture could be deceptive. Do you see those problems with the top side picture? I haven't finalized the fore and aft position yet. How far forward do you think the bar should be placed? thx matt
[img] [/img]
Re: Tubing Bender Questions [Re: bigdad] #1547042
12/15/13 06:43 PM
12/15/13 06:43 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Question only,is there a reason not to use copper tubing for fuel lines?
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Tubing Bender Questions [Re: clonestocker] #1547043
12/15/13 06:50 PM
12/15/13 06:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Notice the end of the motor plate and the location of
your down bar.. if you go forward with the engine, will
you have enough room to drop the back of the engine
to go up and not run into that bar or give you any
hassle with the motor plate on the engine
Re: Tubing Bender Questions [Re: MRMOPAR622] #1547044
12/15/13 06:52 PM
12/15/13 06:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Copper line will work harden and break after time
(if its vibrating)
Re: Tubing Bender Questions [Re: MRMOPAR622] #1547045
12/15/13 06:57 PM
12/15/13 06:57 PM
iowa
W
weinerboy1 Offline
weinerboy1  Offline
W
iowa
Copper from the standpoint of corrosion is superior to steel, but vibrations will fatigue it at the flare. Better use steel, stainless steel. I always tied the front tube to the upper part of the inner fender portion above the A arm section, right at the top where that piece makes the tight upper bend. This is the section spot welded to the inner fender where the upper shock stud comes thru. This is where all the load is on the front end, and in effect triangulates the front bar at that point. Nice job for a first time. Weinerboy1.
Re: Tubing Bender Questions [Re: weinerboy1] #1547046
12/16/13 03:11 AM
12/16/13 03:11 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
If your door bars are not X'ed, you may want to do that now also. If you seal or paint the bars where they go thru the firewall you will see flex right there. Triangulate the upper part of the X bar to the area your front bars meet the A pillar bars and it will eliminate this area of flex. AMHIK Hope this helps, Beep
PS. Looks like you are doing a good job with that bender!
