Re: achieving correct ride height with front coil over
[Re: weedlayer]
#1546858
12/12/13 03:36 PM
12/12/13 03:36 PM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
Determine the stroke of the shock first. After you have figured that you will want 40% of the shaft sticking out at ride height. That will give you 60% for extension. What springs are on the front of the car?
Back in the swing of things at Painless again! Great to be back!
[Re: BJS racing]
#1546859
12/12/13 03:48 PM
12/12/13 03:48 PM
Posts: 2,872 CheddarHead till October
weedlayer
invoice says Qa1 single adjustable shock/ 450# spring. length not specified
sig pic is pre drivetrain install
[Re: weedlayer]
#1546860
12/12/13 03:56 PM
12/12/13 03:56 PM
BJS racing
Arlington, Tx.
If its a bb car then that is close. Might be a bit on the high side but that is ok. Does it have a part number for the shock?
[Re: weedlayer]
#1546863
12/12/13 06:18 PM
12/12/13 06:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Set the lower nut 1" from the bottom... install everything and if it drops down the the 40% point then its good... if you need more than 1" of adjustment change the springs
