changing front axle ujoint #1546789
12/12/13 01:14 PM
12/12/13 01:14 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
I found a well worn ujoint on the front axle steering knuckle.
Have not changed one of these before so wondering what the procedure is or any hints to get it right. I dont have a manual, but probably should!
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: changing front axle ujoint [Re: EV2CUDA] #1546790
12/12/13 01:32 PM
12/12/13 01:32 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
What's it on? a normal dana 44 is pretty straight forward. A spindle nut socket definitely helps even though I've done it with a hammer and punch. On a full time system you will need a 12 point 3/8" (Not 100% sure on the size hopefully someone can help). To take the unit bearing off, it also has to be fairly narrow to fit into the hole.
Re: changing front axle ujoint [Re: CTD5.9] #1546791
12/12/13 01:37 PM
12/12/13 01:37 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
A chrome 3/8 drive 3/8" 12 point socket will get through the rotor on the pre 80 4x4's.
Re: changing front axle ujoint [Re: buildanother] #1546792
12/12/13 01:43 PM
12/12/13 01:43 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Thanks, I forgot the size. I have a socket that was persuaded with a grinder to fit because it wouldn't for some reason.
Re: changing front axle ujoint [Re: buildanother] #1546793
12/12/13 01:45 PM
12/12/13 01:45 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
Its on a 1979 360 engine. I think its a 44 front diff.
BTW, are all engines in these 4x4 trucks tilted to the driver side?
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
Re: changing front axle ujoint [Re: EV2CUDA] #1546794
12/12/13 01:55 PM
12/12/13 01:55 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Search YouTube. Lots of how to videos.
Re: changing front axle ujoint [Re: 76dodgeboy] #1546795
12/12/13 03:56 PM
12/12/13 03:56 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
Took me a bit but found the caliper bracket needed to come off too. Glad I bought a slide puller years ago !
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
Re: changing front axle ujoint [Re: EV2CUDA] #1546796
12/12/13 04:13 PM
12/12/13 04:13 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
yes, on a half ton they do. If it remember right you can wiggle them out on a 3/4 ton. I broke 6 front u-joints mud bogging this year, got some quality experience changing them that I would rather not have.
Re: changing front axle ujoint [Re: CTD5.9] #1546797
12/12/13 08:17 PM
12/12/13 08:17 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
Well I managed to screw up this part. A seal or ring that goes in first before the bearing. What is it and where can I get one?
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
Re: changing front axle ujoint [Re: EV2CUDA] #1546798
12/13/13 02:35 AM
12/13/13 02:35 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Congratulations, now you get to buy a new $100 bearing. Probably needed it anyway. They didn't live long most of the time, few guys ever greased them like there were suppose be have had done. Gene
Re: changing front axle ujoint [Re: poorboy] #1546799
12/17/13 07:04 PM
12/17/13 07:04 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
The part I need is called a seal cup. It holds the inner seal in place. Local napa lists no part. ??? Ideas?
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
