Numbers matching??
#1546214
12/10/13 10:58 PM
12/10/13 10:58 PM
Posts: 345 Ontario, Canada
Hyper Henry
Ontario, Canada
Purchased a 1969 Dart 340 4-speed car and trying to figure out if its the original drivetrain. Not that it really matters to me as I plan on modifying the car anyway and owner did not advertise the car as numbers matching so more for curiosty sake Could a 1969 come with a 69 block?? I always thought the block would have been the year before (ie 68) The engine and tranny are matching and they match the VIN on the dash. But there is no fender tag and no build sheet in the seat I have not dropped the headliner yet to check for build sheet there. Thanks
Re: Numbers matching??
[Re: Hyper Henry]
#1546216
12/10/13 11:32 PM
12/10/13 11:32 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
It is possible that a late build 69 could have a 69 block but typically they will have the previous year casting date from what I have seen. With out a build sheet or a fender tag the scheduled production date is a mystery, maybe someone with a list of VINs and SPD can place yours in a range that might justify the 69 block. If the block has the VIN on the pan rail then I would post a picture of it and let the knowledgeables give their opinion if it is original or restamped.
For what it is worth if it is number matching then I would pull the original drive train and set it in the corner and modify something else, that why you wont damage it and you can always go back.
Careful, your character's showing!
[Re: mopar346]
#1546217
12/11/13 12:07 AM
12/11/13 12:07 AM
Posts: 21,507 N.E. OHIO, USA
A12
N.E. OHIO, USA
Does it have the information when the engine was ASSEMBLED (not cast) Not that familiar with the small block but usually on the BB there is something like E ('69) then the engine displacement 440 (or 340) then below it will be the day 4 (example) and month 6 (June) and HP to the right of the date for High Performance..... Now if that engine assembly date and info is around 2-4 weeks after of the block casting date then you could "assume" it might be the original engine....but there is no guarantee....well without photos for the Moparts
[Re: 4406RAY]
#1546219
12/11/13 01:22 AM
12/11/13 01:22 AM
Posts: 43,544 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Of course 69 Darts can have 69 cast engines, anything built after January 1st 1969 can have a 69 cast block, and the VIN on the passenger side of both will prove it is from that car. I have found plenty of broadcast sheets taped behind the glove box liner, of course the seat bottoms and rear seat back, behind the door panels, under the carpet, and a few in the headliner.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#1546220
12/11/13 01:28 AM
12/11/13 01:28 AM
mopar346
Here's a question for you, is it a GTS or a Swinger? What was the date of the switch over? Could a Dart be had with a 340 without being one or the other?
