enginge lift plate #1544949
12/07/13 08:52 PM
12/07/13 08:52 PM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
do ya'll trust these to lift a big block with an aluminum intake?
Re: enginge lift plate [Re: mprhound] #1544950
12/07/13 08:59 PM
12/07/13 08:59 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I've used mine several times. No issues. I was skeptical at first, but it works great.
Re: enginge lift plate [Re: mprhound] #1544951
12/07/13 09:12 PM
12/07/13 09:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The plate works fine... but I prefer these... I made
my own but its the same thing... great for installing
http://www.summitracing.com/parts/wmr-w41030/overview/
Re: enginge lift plate [Re: MR_P_BODY] #1544952
12/07/13 09:26 PM
12/07/13 09:26 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I just broke the one shown above had to have it all welded up....It was new earlier this year.
Re: enginge lift plate [Re: mprhound] #1544953
12/07/13 09:29 PM
12/07/13 09:29 PM
Az
Crizila Offline
Crizila  Offline
Az
Works on a cast iron headed small blk.
Fastest 300
Re: enginge lift plate [Re: Dragula] #1544954
12/07/13 09:30 PM
12/07/13 09:30 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I actually route an old timing belt through the holes and hook on to that. offers more manueverability for me.
Re: enginge lift plate [Re: mprhound] #1544955
12/07/13 10:18 PM
12/07/13 10:18 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
look's just like the Jegs brand one that I have had for a number of years now and has worked good for just the engine but if i am installing both engine and trans I use the 4 point type that has a screw type adjuster to balance the load and be able to tip it back and forth.
Re: enginge lift plate [Re: mprhound] #1544956
12/07/13 10:41 PM
12/07/13 10:41 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I prefer the tilter from MYKS toolshttp://www.myks-tools.com
Gus
64 Plymouth Savoy
Dana 60
Re: enginge lift plate [Re: fourgearsavoy] #1544957
12/08/13 12:22 AM
12/08/13 12:22 AM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
thanks for the info, I have a tilter, but it is tied up right now and my brother has one of the lift plates, I just don't know if i trusted it enough to use it. thanks for the replies
Re: enginge lift plate [Re: mprhound] #1544958
12/08/13 12:33 AM
12/08/13 12:33 AM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
I had a welder bud make me up FIVE of those .... BUTTT on an alum intake make sure the threads in the intake are good and you use LONG ENUFF bolts or studs OR they could pull out.
Re: enginge lift plate [Re: dOc …] #1544959
12/08/13 12:41 AM
12/08/13 12:41 AM
IN
ahy Offline
ahy  Offline
IN
I have used that type on a full dressed BB/aluminum manifold. No problems. As posted, make sure you have full thread engagement. I gently tighten the carb flange mounting bolts... not full torque to add to the load.
Re: enginge lift plate [Re: ahy] #1544960
12/08/13 03:00 PM
12/08/13 03:00 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'm not a fan of lifting that way
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
