Re: 69 H wheel color?
[Re: DoctorDiff]
#1544874
12/10/13 10:16 PM
12/10/13 10:16 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I call the GM engine compartment satin black, which has more of a matte finish.
Semi gloss black is just a step under gloss black.
Cass, I'm not trying to with you but it's purely semantics at this point.
I believe that Mopar didn't flatten their paint (like GM did) for the majority of their parts (exceptions being dashes, organisol, etc.). Some parts appear "less glossy" than others due to poor materials, shoddy application techniques and time.
I agree that it is sometimes desireable when restoring a mopar to "cut the gloss" or use a bit of flattening agent to reproduce the low quality gloss black that mopar used in these applications...but to say the parts are or were semi-gloss is erroneous IMO.
As it was pointed out in the archived thread, the term "semi-gloss" could be used for something 25% down from full gloss or 70% down from full gloss....the 25% one might appear pretty close, but the 70% one certainly would not which is why I'd rather explain the correct finish as I did; low quality gloss black applied with no particular care as it was just to stop or slow down corrosion.
At the end of the day, there are probably a limited number of people trying to get the finish 100% correct; for the remaining enthusiasts, I'd rather see them use regular gloss black paint than some repro GM semi-gloss which (to me) looks totally wrong.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: 4406RAY]
#1544875
12/11/13 12:05 AM
12/11/13 12:05 AM
Posts: 15,830 Jefferson State
srt
ESYC
ESYC
Jefferson State
I wonder if they dip the wheels on their restorations It's good to hear this as I've suspected they were dipped based on many originals I've seen. As a side note the paint must have been suitable for use as a 'primer' for body colored paint. On an original body color painted wheel I have is a literal rainbow of mopar colors. It appears the hub opening of wheels were placed on a cone shaped fixture and then painted body color. The previous colors were not cleaned from the cone and thus the hub opening has a rainbow of colors glopped there.
[Re: DoctorDiff]
#1544878
12/11/13 01:56 PM
12/11/13 01:56 PM
DPelletier
I never said the factory used semi-gloss paint.
Regardless of what the paint was originally called, the appearance was not gloss black by today's standards.
In other words, if you ask a good shop to paint your wheels "gloss black", the result will be much shinier than the original finish.
....and if you ask them to paint them "semi-gloss" the result will be much less shiny than the original finish.
See what I mean? In any case, if you only had the choice of GM "semi-gloss" and regular gloss paint, the gloss would be far closer to original IMO. If you're more anal than that, then a small amount of flattening agent might get you even closer.
1974 'Cuda
[Re: RUNCHARGER]
#1544881
12/12/13 01:41 AM
12/12/13 01:41 AM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
I agree with the poorly applied gloss black but what I'd like to know is how they got it to stick so well and be so hardy? A lot of that paint is still stuck onto the parts much better than what we do now with modern primers, supercleaning the parts and sanding them for bite.
Sheldon
lead and/or other paint additives that are no longer used
[Re: 6bblgt]
#1544882
12/12/13 11:45 AM
12/12/13 11:45 AM
srt
ESYC
ESYC
Jefferson State
Sheldon
Perhaps, but more likely a chemical etch prior to dipping Maybe someone up north had a relative that worked at one of the plants?
[Re: srt]
#1544883
12/12/13 01:13 PM
12/12/13 01:13 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Ever strip an original wheel? Nothing but black paint. Bare metal dipped in heavy cheap black enamel. Here is the back side of an original spare. Basic black with body color sprayed on the front side. You can see the blue in the slots. We way over anal-ize these parts. Cheap and fast was the rule of the day when these cars were built.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#1544886
12/12/13 03:31 PM
12/12/13 03:31 PM
Posts: 21,526 N.E. OHIO, USA
A12
N.E. OHIO, USA
Are there ever any runs or drips like on some other things that are dipped (i.e., torsion bars, etc.)?
[Re: A12]
#1544887
12/12/13 03:59 PM
12/12/13 03:59 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Torsion bars???
Yes...
[Re: RSNOMO]
#1544888
12/12/13 04:27 PM
12/12/13 04:27 PM
A12
N.E. OHIO, USA
Torsion bars???
Yes...
Torsion was my example of a dipped part that has drips and runs......do the wheels have them?
[Re: A12]
#1544890
12/12/13 08:50 PM
12/12/13 08:50 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Personally, my belief is that flawless paint on ANY component of these cars is a stretch from OEM...
[Re: DPelletier]
#1544892
12/13/13 08:36 PM
12/13/13 08:36 PM
A12
N.E. OHIO, USA
You've got that right; my 'Cuda had all original paint everywhere and perfect was nowhere to be seen!
My question was really to do with "does a dipped component have any indication of the process used to cover it with paint?"
If I brush painted an item someone could sure tell, if I used a paint roller someone could sure tell, when I look at a torsion bar I can see the drip marks still there and know it was coated with paint by dipping it.................so how is anyone sure of the process of how black steel wheels are done and if the car is to get body matching color how is that done, by dipping too? (I know they are not because the backs are not body color) Anyone have any manufacturing photos of how the wheels were done back then..if not then where is the evidence (drips, runs, errors,) that indicates they were dipped?
[Re: Stewpar]
#1544893
12/13/13 08:44 PM
12/13/13 08:44 PM
BradH
I sure hope end of the world decisions don't come down to a debate over percentage of gloss.............
You ain't been around the A12 restoration guys much, have ya'?
Darn, I sure miss mine...
