Re: 440 Source CNC heads
[Re: 440Jim]
#154469
11/22/08 01:32 PM
11/22/08 01:32 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Anyone have any good pictures of the CNC heads chambers? I want to run a set on a 383 and I am concerned about the compression.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: dare_dude]
#154473
11/22/08 04:14 PM
11/22/08 04:14 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
That's an awesome price for a CNC ported head that flows that good. I would jump all over that if starting from scratch. They're probably very similar to my old Eddy heads that ran 9's on a streetable combo, great deal.
[Re: moparniac]
#154476
11/24/08 07:02 AM
11/24/08 07:02 AM
Posts: 5,875 communist bloc of new jersey
jamesc
The set my buddy got needed corrected all over the place... Im not gonna say the comments he got from you know who so he dont get bent out of shape about it.... but I would buy a worked used set of eddy's off here from an experienced member before going that route...
would you care to elaborate on that? if Jeff is doing the finish work i'm having trouble understanding what needs to be corrected.
[Re: moparts]
#154480
11/24/08 10:27 PM
11/24/08 10:27 PM
Posts: 1,760 Port Alberni, British Columbia
MoparDonny
At this point I would not bother to listen to any thing wedgeOmatic has to say when it comes to 440source, He has posted in the all 440source threads about his valve cover problem many times over and over
Well said!!! Getting very old seeing his continuous whining of 440 source parts. Give it up already, Wedgy!!!
[Re: rustbucket]
#154483
11/24/08 10:49 PM
11/24/08 10:49 PM
MoparDonny
There is one problem with the heads though. I went to order a set about a month ago and the only way they will sell them is complete with springs for a small cam. I want to run a hydraulic roller so the springs, stc would be useless! Why won't they sell them bare.... or has this changed
I would think it's because MCH has adjusted the Valvetrain and checked all the clearances in the whole assembly and it's just part of the deal. I would think they could have bare CNC'd ones in the future. What exactly is a smallish cam. I think even the EDDY RPM's can handle up to 600 lift on stock springs, even though they likely won't handle it as I've heard before.
Don.
[Re: moderncylinder]
#154484
11/24/08 10:51 PM
11/24/08 10:51 PM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If i were out to build a 700 hp budget motor, this is where i would start. The heads flow enough to make the power, and the price is right. Put them on a 535 inch rb 4.5 stroke shortblock, shift at 5800 rpm!
#154489
11/25/08 10:19 PM
11/25/08 10:19 PM
Posts: 3,095 Idaho
Runner
Idaho
if its a car quicker than 12.0,, id add the inner
thats interesting, why does et make a differance?
#154491
11/26/08 03:35 AM
11/26/08 03:35 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
this really doesn't make any sence, the ET really hasnät got much to do with the engines accelration rate. How aboout the number of gears, engine rpm range, total gear ratio etc?
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#154492
11/26/08 08:47 AM
11/26/08 08:47 AM
Posts: 1,752 detroit area
moderncylinder
detroit area
its a generalization,, more power the engine makes the quicker it will acclerate the car theefore acclerating the engine/valvetrain quicker,,, common sense.. you could have some 572 with a small hyd cam that has a 2.73 gear that can go 11's , or something to that nature,, that makes my reasoning fail,, but again its a generalization. like a 590 cam in a 4000lb car with a 440 that is pump gas and runs 12.50's,, then take a 590 cam in a 528 or 540 that has high compression in a 2500lb drag car,, the spring requirements are not the same,, again common sense.. i have "general" rules for setting heads up based on cam, rocker ratios, rear end ratio, total lift, how many gears, how quick the car is overall,, most people put in the rear end ratio to max engine speed at the expected targeted 1320ft mark.
[Re: thecarfarmer]
#154494
11/26/08 12:41 PM
11/26/08 12:41 PM
Posts: 982 mopar heaven
rustbucket
mopar heaven
No mention of getting 'em w/o springs & etc. on their web page; they don't list any heads (ported or not) bare or bare w/ valves.
Kinda' sux, 'cause I have a solid roller, and have already purchased springs/retainers.
-bill
This is my point exactly. If you have parts already why would youbuy them again. Does anyone else make you buy their heads complete!!!!!
[Re: rustbucket]
#154495
11/26/08 12:53 PM
11/26/08 12:53 PM
DaytonaTurbo
Manitoba, Canada
If memory serves, brandon's reasoning for this was so many people wanted to buy the heads bare but with valves. He decided that he would just sell the whole thing because you'd still be ahead of the game even if you had to replace the springs/retainers. Probably just easier for him to sell them whole.
[Re: rustbucket]
#154496
11/26/08 01:01 PM
11/26/08 01:01 PM
moderncylinder
detroit area
maybe he could sell them without the springs and so on,,, maybe he would drop the price 30 dollars or something,, see them for 869.00,,, or even maybe 859.00..
edelbrock does not sell their performer head as a head w valves only,, if you bought the casting and then bought valves you would have the same amount of money as if you bought the assembled head from them.
what i would be asking for is a "race" version with a double spring and 10 degree locks and retainers,,, maybe he could offer that kind of an upgrade for 50-75 bucks more.
jeff
[Re: Dave64]
#154498
11/26/08 02:10 PM
11/26/08 02:10 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Id buy a set with the spring upgrade for sure.
[Re: domingo]
#154499
11/26/08 02:45 PM
11/26/08 02:45 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
I bet that 440source doesn't sell them sans springs because it requires a separate SKU/stocking number. The difference of $30 doesn't make economic sense due to potential lost sales from the complete units. Easier to stock one unit for the marginal difference. Heck, if I bought them and didn't want the springs/retainers, I'd give them to someone doing a milder build. If $30 is a budget buster?
[Re: Von]
#154505
05/16/09 08:42 AM
05/16/09 08:42 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
I changed my springs retainers amd keepers.My machinist said they would be OK for a smaller hyd cam but I run a .588 solid.I sold the parts to a guy for 40 bucks and we were both happy.Rocky
Chrysler Firepower
[Re: dthemi]
#154511
05/16/09 09:41 PM
05/16/09 09:41 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
For as little as these heads cost complete, you could just throw the springs away and still be ahead of the game. It's encouraging to see good bargain heads for a Mope, like Ford and Chevy have falling out of the sky.
why all the drama.. I replaced the springs on my Edelbrocks, don't recall having to whine about it...
[Re: dthemi]
#154512
05/16/09 10:00 PM
05/16/09 10:00 PM
Posts: 1,472 Overland Park, KS.
Joshs68
Overland Park, KS.
exactly I wish these were available when I built my car!
[Re: 1_WILD_RT]
#154513
05/16/09 10:00 PM
05/16/09 10:00 PM
Posts: 2,119 sc
tjmarcus1
sc
well said!
[Re: tjmarcus1]
#154514
05/17/09 12:01 AM
05/17/09 12:01 AM
Posts: 301 central Pa.
71Pan
central Pa.
These heads are worth 1995 bare! . I have had more in 915's 20 years ago. Some opions on this board chap my hide!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[Re: dare_dude]
#154517
05/18/09 10:15 AM
05/18/09 10:15 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
We just put on a set this past week on a car that has .590 cam with 915 heads with a crossram. The car only made 2 passes with this combo and went 11.00 @120mph. Put the cnc heads by jeff on and went 10.47@127 at cc. in colombus this past wkend. Jake
JAKES AUTOMOTIVE
[Re: JAKE68]
#154518
05/18/09 10:33 AM
05/18/09 10:33 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Jake What was the car spec. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: JAKE68]
#154521
05/18/09 01:34 PM
05/18/09 01:34 PM
Posts: 996 Queens, New York
Harley
Queens, New York
We just put on a set this past week on a car that has .590 cam with 915 heads with a crossram. The car only made 2 passes with this combo and went 11.00 @120mph. Put the cnc heads by jeff on and went [Email]10.47@127[/Email] at cc. in colombus this past wkend. Jake
Nice gain. Did the 915's have any port work done to them?
[Re: Harley]
#154522
05/18/09 02:59 PM
05/18/09 02:59 PM
JAKE68
Shelby mi.
Yes they had a nice port job on them and they had 2.14/1.81 valves. They also had a maxwedge intake port.
JAKES AUTOMOTIVE
[Re: sshemi]
#154525
09/27/09 09:53 AM
09/27/09 09:53 AM
gregsdart
Are the intake valve seats big enough to go 2.19 valves, and is there enough meat in the throats to match? What is the cost for a cnc ported set from mch?
