Re: 440 Source CNC heads
[Re: 440Jim]
#154469
11/22/08 01:32 PM
11/22/08 01:32 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Anyone have any good pictures of the CNC heads chambers? I want to run a set on a 383 and I am concerned about the compression.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: dare_dude]
#154473
11/22/08 04:14 PM
11/22/08 04:14 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
That's an awesome price for a CNC ported head that flows that good. I would jump all over that if starting from scratch. They're probably very similar to my old Eddy heads that ran 9's on a streetable combo, great deal.
[Re: moparniac]
#154476
11/24/08 07:02 AM
11/24/08 07:02 AM
Posts: 5,875 communist bloc of new jersey
jamesc
The set my buddy got needed corrected all over the place... Im not gonna say the comments he got from you know who so he dont get bent out of shape about it.... but I would buy a worked used set of eddy's off here from an experienced member before going that route...
would you care to elaborate on that? if Jeff is doing the finish work i'm having trouble understanding what needs to be corrected.
[Re: moparts]
#154480
11/24/08 10:27 PM
11/24/08 10:27 PM
Posts: 1,760 Port Alberni, British Columbia
MoparDonny
At this point I would not bother to listen to any thing wedgeOmatic has to say when it comes to 440source, He has posted in the all 440source threads about his valve cover problem many times over and over
Well said!!! Getting very old seeing his continuous whining of 440 source parts. Give it up already, Wedgy!!!
