Dodge caravan code p1684. Help ASAP!!!! #1544449
12/06/13 01:15 PM
12/06/13 01:15 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
I'm in a pickle. Suppose to leave this afternoon with the van. Check engine light came on. Code p1684. I searched online n it says battery voltage caused it on others or battery disconnected. We just put a battery in on Tuesday. Says within last 50 starts. Am I over looking it? Wife says its not down shifting. Help
Contact Me about AMD Prices
Re: Dodge caravan code p1684. Help ASAP!!!! [Re: hotairballoonpilot] #1544450
12/06/13 01:24 PM
12/06/13 01:24 PM
St. Charles, MO
wingman Online happy
Uncreative Title
wingman  Online Happy
Uncreative Title
St. Charles, MO
A 1684 would be present if you disconnected the battery, but I do not believe a 1684 by itself will cause the CEL to come on.
Any other codes present? Are you doing the key dance or using a code reader?
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Dodge caravan code p1684. Help ASAP!!!! [Re: wingman] #1544451
12/06/13 01:38 PM
12/06/13 01:38 PM
South Dakota
South Dakota
Advance auto read it for her. They said its Code is P1684 power to module disconnected. She says not down shifting
Re: Dodge caravan code p1684. Help ASAP!!!! [Re: hotairballoonpilot] #1544452
12/06/13 01:58 PM
12/06/13 01:58 PM
South Dakota
South Dakota
How many times do yturn key on n off to get codes?
Re: Dodge caravan code p1684. Help ASAP!!!! [Re: hotairballoonpilot] #1544453
12/06/13 02:15 PM
12/06/13 02:15 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
3 on off on off on
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Dodge caravan code p1684. Help ASAP!!!! [Re: hotairballoonpilot] #1544454
12/06/13 04:57 PM
12/06/13 04:57 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Are you sure that it is not downshifting entirely? Remember it has an adaptive transmission. It has to relearn all of its preferences. My Caravan had some funky shifts after changing the battery out but it eventually learned what was up.
Did they reset the code? If they did and the light went out, all is good. If they did not, it will take a number of key cycles to turn it off.
Craig
Re: Dodge caravan code p1684. Help ASAP!!!! [Re: denfireguy] #1544455
12/06/13 05:02 PM
12/06/13 05:02 PM
South Dakota
South Dakota
Speed sensor. Just got it checked.
Re: Dodge caravan code p1684. Help ASAP!!!! [Re: hotairballoonpilot] #1544456
12/06/13 05:03 PM
12/06/13 05:03 PM
South Dakota
South Dakota
P0700 is code.
Re: Dodge caravan code p1684. Help ASAP!!!! [Re: wingman] #1544457
12/06/13 06:09 PM
12/06/13 06:09 PM
South Dakota
South Dakota
It's shifting fine. Shop said speed sensor was the fault code on the snap on reader. I watched him run code. It acted up for the wife but I've driven it around town last two hours I bet a good 10-15 miles and no issues. Wife was driving it and it hasn't acted up or slipped shifting. It was drive after battery switched out Tuesday pm I'm guessing close to 50- 75 miles.
