Time for another mini van question (trans) #154443
11/21/08 03:22 PM
11/21/08 03:22 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
Was told its a A604 speed sensor problem ???? is it cheap and easy to fix ?????
Re: Time for another mini van question (trans) [Re: theraif] #154444
11/21/08 07:36 PM
11/21/08 07:36 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
output speed sensor problems are common on 604s the sensor is less than 30.00 from dodge the last time I purchased one
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Time for another mini van question (trans) [Re: dusturbd340W5] #154445
11/21/08 07:43 PM
11/21/08 07:43 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
ere are 2 speed sensors input and output,both in the front easy to get to...what problem do u have with it?
Re: Time for another mini van question (trans) [Re: AARCONV] #154446
11/21/08 08:43 PM
11/21/08 08:43 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
Not mine one thats for sale was told can zip around town all day as long as it 25-35 mph or so, i guess its not happy going faster
Re: Time for another mini van question (trans) [Re: theraif] #154447
11/21/08 09:17 PM
11/21/08 09:17 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
if u don't know the history of the van I would not get involved with it...unless u get it dirt cheap...they do have problems...
Re: Time for another mini van question (trans) [Re: AARCONV] #154448
11/22/08 10:18 AM
11/22/08 10:18 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
They are easy to change but the vans have known tranny problems. I changed mine then not long after I had to rebuild the tranny.
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: Time for another mini van question (trans) [Re: moepwr] #154449
11/22/08 10:23 AM
11/22/08 10:23 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
input/output speed sensors very common.yes there are codes for them.usually the speedo goes out also.and the trans will go into limp mode.Stay in second gear ,not shift up or down.
Re: Time for another mini van question (trans) [Re: theraif] #154450
11/22/08 04:36 PM
11/22/08 04:36 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
if it works ok at lower speeds then it's not a speed sensor issue
Re: Time for another mini van question (trans) [Re: gtx6970] #154451
11/22/08 04:42 PM
11/22/08 04:42 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
that sounds like second gear to me.
Re: Time for another mini van question (trans) [Re: bboogieart] #154452
11/22/08 07:31 PM
11/22/08 07:31 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
thanks
