trans brake tuning advice? #1544267
12/05/13 10:09 PM
12/05/13 10:09 PM
duster408 Offline OP
I am needing some help in calming my car down when leaving off the brake. If I footbrake my car pulls the wheels about 2 ft with a 1.27 60 ft. When I leave off the brake at 4300 it is almost on the bumper with a 1.22 60 ft. Other than wheelie bars, any ideas on what to do??
Re: trans brake tuning advice? [Re: duster408] #1544268
12/05/13 11:33 PM
12/05/13 11:33 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Did u try turning down ur launch rpm?
Re: trans brake tuning advice? [Re: duster408] #1544269
12/05/13 11:41 PM
12/05/13 11:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the rear suspension
Re: trans brake tuning advice? [Re: MR_P_BODY] #1544270
12/05/13 11:53 PM
12/05/13 11:53 PM
I havent tried a lower launch, how much lower? It is ladder bar.
Re: trans brake tuning advice? [Re: duster408] #1544271
12/06/13 12:01 AM
12/06/13 12:01 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i dunno about lowering the launch, i do bigger wheelstands when i launch at 3800 than i do set at 4800.
Re: trans brake tuning advice? [Re: duster408] #1544272
12/06/13 12:02 AM
12/06/13 12:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Start a thousand rpm lower and work from there... add
some air pressure to the slicks.. strap the front down
Re: trans brake tuning advice? [Re: rebel] #1544273
12/06/13 12:04 AM
12/06/13 12:04 AM
I thought a lower launch would make a greater gap for the converter to flash and would make it hit the tires harder.
Re: trans brake tuning advice? [Re: duster408] #1544274
12/06/13 12:09 AM
12/06/13 12:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Try it... I dont have any issue with wheel stands at
lower rpm
Re: trans brake tuning advice? [Re: MR_P_BODY] #1544275
12/06/13 12:26 AM
12/06/13 12:26 AM
NY
challenger451ci Offline
NY
Have you tried to slow things down with shocks at all? I know my car needs a fair amount more shock dampening between foot braking and using the TB.
Re: trans brake tuning advice? [Re: duster408] #1544276
12/06/13 12:26 AM
12/06/13 12:26 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Do you have adjustable front shocks? If so... try tightening up the extension.
Don't knock power out of it, figure out how to make the car go forward instead of up!
Re: trans brake tuning advice? [Re: dizuster] #1544277
12/06/13 12:29 AM
12/06/13 12:29 AM
NY
NY
What he said^^^^^^^^^^
Re: trans brake tuning advice? [Re: duster408] #1544278
12/06/13 12:48 AM
12/06/13 12:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Put the front of the ladder bars in the lowest hole...
you may need to add lower holes also if it cant angle
down enough... add more air to the slick to get a
controlled amount of spin... I do that also... dead
hooking isnt the quickest way
Re: trans brake tuning advice? [Re: MR_P_BODY] #1544279
12/06/13 08:13 AM
12/06/13 08:13 AM
Q
Quicktree Offline
Quicktree  Offline
Q
start at 3000 rpm off the brake. every car I have ever driven was less violent with lower rpm. I have not lost anything in 60ft. if it's a heavier car reaction time may be a little slower.
Re: trans brake tuning advice? [Re: duster408] #1544280
12/06/13 08:15 AM
12/06/13 08:15 AM
Q
Quicktree Offline
Quicktree  Offline
Q
thats what they say but I am yet to experience that in a number of different cars and combo's
Re: trans brake tuning advice? [Re: Quicktree] #1544281
12/06/13 02:08 PM
12/06/13 02:08 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Pull the chip out and leave off the converter. All cars are different and will react differently to changes. Ladder bar cars tend to be harder to tame down, but you don't want a dead hook, nor do you want to blow the tires off, you DO need to know where the happy spot is with the most tire pressure, not the least pressure. I see a long TNT session in your future.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: trans brake tuning advice? [Re: MR_P_BODY] #1544282
12/06/13 02:26 PM
12/06/13 02:26 PM
gregsdart Offline
gregsdart  Offline
lower rpm
I agree. Start with the rpm lower, adjust as needed. You can also try a more aggressive setting with the shocks and ladderbars in the back, but the launch rpm will need to be high enough to bridge the gap between the weight transfer of the suspension and the hit of the converter. If it isn't balanced, the result will be spin after the initial move. The last place to work is the front, starting with shock settings, then limiting travel.
Its, a balance, and if the car is set up with too much launch torque and too high of a CG, wheelie bars may be needed to fix the issue. The last place to work is the front, starting with shock settings, then limiting travel.
Re: trans brake tuning advice? [Re: gregsdart] #1544283
12/06/13 02:32 PM
12/06/13 02:32 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
1-I would not try more than one change at a time
2-I would not go for more air in the tire and less traction
3-scaling the car will really help you set it up where you want it
4-I would lower your launch rpm
We could launch off our TB at stall but if we use it, I launch anywhere between 1900-2500...Foot brake the same way. When we want to hold the front end down, we shorten the front travel limiters...Us bracket racers don't generally try to run the car on kill mode every pass down the track...We look for consistency...
Re: trans brake tuning advice? [Re: duster408] #1544284
12/06/13 02:48 PM
12/06/13 02:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would NOT pull the launch chip out.. in my sig pic
thats a 5600rpm launch with no chip... if it werent
for the wheelie bars my car WOULD fill over... the pic
with 6" or so wheels up is a lesser launch rpm... in
the sig pic that is a 1.19 60' the lower wheelie is
a 1.22 60'... I control with spin with a 1/8 psi to
1/4 psi adjustment in the tire pressure(once you find
the happy pressure)... depending on the weight bias
and CG of the car you will/might end up with different
numbers for your launch rpm and tire pressure... once
you get a decent launch then you can fine tune the
shocks to the rpm...... but lower the front of the
bars so it pushes forward and not as much up... start
out with a SAFE launch before you bust up the car
Re: trans brake tuning advice? [Re: MR_P_BODY] #1544285
12/06/13 05:05 PM
12/06/13 05:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You need to focus o the suspension. Shock settings etc. You are dead hooking the car causing it to wheelie. Assume with those 60's it is a fairly quick car so what ya want is wheelspeed that will tame down the wheelies as well. Ladder bars are inherently violent so you will likely need to at the very least make some shock changes if not moving the bar to a different hole.
Re: trans brake tuning advice? [Re: Al_Alguire] #1544286
12/07/13 11:23 AM
12/07/13 11:23 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
I was just having a conversation similar to this. The Cuda is running the best et's ever (9.95) but, it seems the '60 has fallen off a bit. Now a 1.39 used to be 1.36. Question is... how much under your converter flash should your brake chip be?
